Ouch.
2020 RTL SE6
Originally Posted by JCSMOKE
You know your not doing it right if you don't have extra parts when you are done, plus you get better gas milage due to the reduced weight.
That only applies to Chevys!
Well I am not trying to brag but I have never had any parts left over unless the kit from BRP came with new replacement screws.....
But I will say that I bet most the folks that have left over panel screws, check behind your mirror! Even my dealer forgot one on each side under there.
Bob
2011 RT-S SM5 - Black
Drove about 60 miles today with the new tire. I'd almost swear the bike rides smoother, but sure don't think a tire change would be that noticeable. Could that really be the case or am I just imagining things?
2014 Copper RTS
Mine was the same way, I think it rides better
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
Chevys must get better gas mileage all the time then since parts constantly fall off of them.
Originally Posted by WasWinger
I've got a good start! I have 2 body panel type screws left over from installing the Tri-axis handlebars yesterday!
Figured out where the screws belonged. Bottom two tabs for the center piece around the headlights! I took a bunch of the tupperware off so the service tech doesn't have to figure out where all the wires to and from the console go for my mods. He has to remove it to change the DPS module tomorrow.
2014 Copper RTS
Forgot to mention no washers under my caliper bolts when I did my tire....
Tire change
I just changed out my rear tire on my 2014 RT.I jacked it up walked the belt off replaced tire put axel back in wheel.Walked belt back on never touched belt adjusters or rear shock.Everything lined up and runs perfect.
I don't know why I didn't try "walking" the belt back on. Maybe would have worked. Oh well, if I'm fortunate, in more ways than one, I will never have to change the rear tire again! By the time it wears out hopefully I'll be able to trade for a '14 or '15 RT!
2014 Copper RTS
Too old and crippled now those days are gone for me, but I can still change my own oil for now.
Mine also in front
Originally Posted by billybovine
I was at the dealer to get a rear shock replaced today. While there I asked about the shim. The 2 mechanics agreed they had only seen 2 so far with a shim and both where between the caliper and the bracket, front bolt.
I also have a washer shim on the front bolt between caliper and bracket. It was "glued" with yellow locktite. We still can see the mark on the braket.
Richard ST 2013
SpyderLovers Sponsor
Washer
Front bolt, between caliper and mount.
We got a time of 36 minutes to pull the rear wheel and throw it in the car. 21 to reinstall. We did 3 in a week. We get lots of practice!!
Joe Meyer
