Results 1 to 11 of 11
Thread: 2014 RTS
    Active Member CMA Cowboy's Avatar
    Waynesville, Missouri
    Default 2014 RTS
    Really like the 2014 RTS now that the Elkas are installed. Do miss the frunk button. Now to build up to the 40+ mpg folks are talking about.
    Ray
    "Instead of arriving in Heaven in a nice well perserved body I'd rather slide in feet first, all beat up, loudly proclaiming thank you Jesus for a great ride!"
    Default Great..!!
    just some constant checking for about 5,000 miles and you should be there. You will still be smiling till you get there and hopefully won't distract you from the real joy of this ryde...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    I found the 40 mpg when I got to the third tank or so. Now its pretty much 40 mpg every tank. 6500 miles and counting.
    Danbury Connecticut
    How are your front tires holding up?
    IBA #47122
    2020 RT Limited Asphalt Grey
    Mar 2013
    For me it was around the 2000 mile mark before I hit the 40. Your milage may very, but it will come
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    I started seeing 40 mpg at about 1,000 miles.
    But; I've always been pretty darn close to it!
    Very Active Member bluestratos's Avatar
    Jun 2011
    Lynden, WA
    I have 2700 miles and have only seen 40 mpg once, my last tank, which was a long highway run in a group was 36.2. Im not complaining, just voicing in. By the way, to install your own electric trunk release is easy and cheap, I did mine for under $20 using a door lock actuator and a momentary contact switch.
    Aug 2012
    Central Coast, CA
    Quote Originally Posted by CMA Cowboy View Post
    Run it in eco mode, shift early, and keep your speeds down and you'll do it.
    2020 RTL SE6
    So far, both front and rear tires are looking good. I am thinking at least 10K on the rear, the fronts still look new. Hoping for the usual 20K plus on them.
    SoFlo
    40 mpg...I think for us it would require the stars to align and something broken in the twist grip to limit rotation.
    Maybe the cat bypass will pay for itself in saved fuel.
    PK
    Very Active Member Jim&Teresa's Avatar
    Jun 2013
    Woodbury, MN
    Default 40 MPG possible around 1500 -2000 miles - my experience
    First mileage on the 2014 RT was around 32-34 mpg.......then by the time I was near 1500 miles it was near 40 mpg! Hit 40+ mpg by the time we were at 2000 miles....
    I just keep smilin' when rydin' the 2014 RT Limited - - it's an AWESOME machine...the mileage is a bonus, the machine is smooth, quiet, lower rpm, etc......did I mention it is AWESOME! Now we have 8000 trouble free miles on it....just great! Only issue: rear tire life. Just replaced our rear tire. You probably have seen that posted on the forum. Not a big issue, just an inconvenience.
    Happy and safe rydin'
    2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
    2014 RT Limited , Cognac
