Results 1 to 13 of 13
    May 2014
    Texas
    Default 1330 gas cap problem
    Been noticing that when I unscrew my gas cap there is some small bits of plastic that come out of the cap and fall below the filler mouth... been thinking this is not good... called my dealer and told him I think there may be a problem and I had better get it replace soon... He agreed and said just bring the old one in and he would replace it.... Well last night I was going to take it off and bring it in this morning to replace it.....Dugh!!! could not unscrew it... all the little ratchet teeth were gone from the last time I put it on.....So I got a large pair of channel locks and gripped the outside cap real good and got it off.... Just a heads up.... you see those little bits of plastic..... REPLACE......
    Registered Users acinpcola's Avatar
    May 2011
    Cantonment, FL
    Thanks for the heads-up on this
    2014 RT S SE-6 Cognac, 2014 Indian Chieftain. Retired Navy Chief
    Glad to hear that you noticed it, and had a fix in the works!
    May 2014
    Texas
    Just glad I was not on the road needing gas....
    washington state
    Large channel lock is my fab tool.
    2012 Spyder RT SE5 Brake pedal mod
    In this instance; it sure works better than a large hammer!
    Registered Users Dragonrider's Avatar
    Feb 2009
    Canby, OR
    Much less satisfying than a large hammer tho....
    2014 RT SE6 Rider
    X - Honda Rider
    X - RT S driver
    X - RS driver
    Lifetime VFW Member
    Active Member snics's Avatar
    Dec 2013
    Chelsea, Quebec, Canada
    Its a known issue.
    My dealer replaced mine also, no hassle.
    When it starts happening, don't tighten all the way to the ratchet.
    Jax Beach, Fl.
    What's different about the replacement cap? Will it do the same thing over time as the original Cap?
    2014 RTL-SE6 Cognac (Current Love)
    2012 RTS-SE5 Pure Magnesium Metallic (Pre Loved)
    Default Known problem..!!
    several have posted about this issue. They have a replacement cap they should replace it with. The ratchetting mechanism seems to crumble and sqeezing the sides is about the only way to remove it depending on how broken up it is. Fortunately the pieces that may fall in the tank just stay there...
    ​2012 RS sm5
    Jun 2011
    Near Lexington, NC
    Gas caps from any junk yard or auto store fits.
    Mine was so hard to open when I first got it, I replaced the large O ring with one off a spare cap I had. It can now be ratcheted as much as I like but will open with minimum twist.
    Been that way for 10K now with no issues.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Active Member viperryder's Avatar
    Oct 2011
    Ohio
    Default Bad cap
    Quote Originally Posted by bgame View Post
    Have had the same problem, but thought is was me.
    2014 RTS SE6 , Cognac
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    I've never had an issue with mine, but as a preventative, I only tighten to snug, and never twist until it clicks.
    2020 RTL SE6
