Page 2 of 2 FirstFirst 12
Results 26 to 39 of 39
  1. #26
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by JoeUpchurch View Post
    Billy, how could this be? The jumper post was a solid connection to the battery, the dealer mentioned that they should have caught it at the 4600 inspection - just makes no sense to me - I made sure that the thing was tight from the top. Help, please.
    Well if it's not that one there must be others. I do not have 2012 service manual so I can't look it up. Then it still would be a guess. Why not ask the dealer where it was?
  2. #27
    Active Member JoeUpchurch's Avatar
    May 2014
    Lugoff, SC
    Cool Ground wire to oil tank?
    Joe,
    Is your bike now starting normally for you?
    If so...
    My dealer's tech says the ground wire on the oil tank was loose. Now runs as designed. Dealer covered under warranty. Happy to ride again!
  3. #28
    Jul 2011
    Thanks for letting us know. It may help someone else in the future.
  4. #29
  5. #30
    May 2014
    Lugoff, SC
    Seems there are 3 major chassis grounds, anyone know where the third is ?
  6. #31
    May 2014
    Lugoff, SC
    One more observation about my 2012 RT Ltd not starting. The next day (after dealer found ground wire to the oil tank loose) I rode for 100 Miles to Ricky Clayborn's house for his laser alignment and back home only to hear the clicking sound once more the next morning. I had forgotten to plug the battery maintainer in and with subsequent testing of everything I could think of I finally found that the iPod in the trunk and the 660 Garmin when left on the Spyder draw just enough current to kill your next start up attempt. I can say that conclusively (I think) because as soon as I hooked up a battery charger set to deliver 40 amps it started strong re than usual. Additionally, by disconnecting the Garmin and the iPod the maintainer indicates full charge a whole lot faster. So, if you have starter problems and you've ruled out everything else - this is something else to check.
  7. #32
    Jul 2011
    The iPod will be drawing power. Not enough to be concerned about. The Garmin GPS gets it's power from the radio and when the radio turns off with the key, no power goes to the GPS.
    On my Spyder the alarm, the BT dongle and my Sena headset are drawing power when parked. I can go for a 1 1/2 weeks before I have any starting trouble. I don't use the maintainer unless I think it will be sitting for more than a week.
  8. #33
    Active Member Dizneyman's Avatar
    Sep 2011
    Cocoa Beach, Florida
    I have a 2011 RT-S, originally battery, always leave Garmin on Bike and IPOD in trunk hooked up. Never has used a battery tender, and never an issue starting... (until I go down later for opening up my big mouth.)
    I doubt that is your issue, leaving them on the Spyder. As a note, when I turn bike off, Garman says power lost, turning off in 30 seconds... does your say that?
  9. #34
    Lugoff, SC 29078
    Default Up and running just great!
    Joe,
    If so...
    Wind in my hair again! Darn - won't start again - called best plus for a tow
  10. #35
    Lugoff, SC 29078
    Question Recurring -clicks but won't start- believe it!
    Hi everybody,
    I've read every post I can find on this subject, pulled every relay, pulled and checked every fuse, tightened every battery terminal, unit shows 12.8 at the battery and the frunk accessory 12 V plug as well as the brunk accessory 12 V plug, The dealer installed a new battery on 5/28/14. My dealer isn't open till Tuesday, anyone got any more suggestions? I suspect bad cell in the battery with less than 300 miles traveled however, no bulging on it. I have a 12V battery load tester and will try that tomorrow.
    Appreciate any help - thanks,
    Joe
    . Second time BEST PLUSS towed it to dealer!
    stopped for gas after 75 mile ride - I guess I'll just have to get used to my BEST PLUSS rep!
  11. #36
    Lugoff, SC 29078
    Question Yes, it does
    Quote Originally Posted by Dizneyman View Post
    Yes, First time towed they said it was a bad ground at the oil tank - what will they say this time? BEST PLUS pays $200 for every tow, maybe the second time they will find the problem.
  12. #37
    illinois
    Default Hi my 2012 has a starting problem too
    Hi , my 2012 rts , has a starting problem too. I drive it often & keep it on the batty tender. I put in a new battery. I think it is the start switch on the handle bar. But dealer won't change the switch for me. Transmission in natural, I push the start button & nothing happens.
  13. #38
    Jul 2011
    Quote Originally Posted by project.618 View Post
    You would be better off starting your own thread so we can deal specifically with your Spyder's starting problem.
    When you push the start button and nothing happens it is not a battery problem. As you found out.
    Is the engine stop switch in the run position?
    Is your foot pressing down the brake pedal?
    When you press the brake pedal are the brake lights coming on?
    When you first turn the key on, do you hear the fuel pump run?
    After about a minute after first turning on the key. Does the message "Bad Key" scroll across the screen? Warning it may only do this once.
  14. #39
    Feb 2012
    Spring City,Utah
    So our last post from Joe was that he was going to the dealer again. Did we ever hear any more from him? Do we know if this got resolved and if so what that was? Joe where are you?
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
Tags for this Thread
