brake light stays on
anyone know the service bulletin number for this, says something about replacing switch and bracket
what year and type of spyder is it, i had the problem on my 13 rt and there was no fix or recall for it
NO BIKE AT THIS TIME
Need more to go on..!!
your profiles lists nothing. You can start by checking the brake switches at the pedal and the master cylinders. Spray some contact cleaners and adjust as needed. Call your dealer with vin # to see if there are any updates needed to be done...
2012 RS sm5
Take your foot off the brake.
Lol
Originally Posted by Rattigan_Roger
In other threads it has been discussed that STs have a problem with dirt getting into the switch.
It's a warranty issue.
I know it is warranty that's why nI wanted the service bulletin number my dealer can't seem to find it
it is a 2013 st, that why I posted in st forum
I haven't heard of this issue, would like to know what they find.
Thanks for posting.
Brake Light
Larry it's probably your brake light switch. It tends to get dirt or grit in it and starts sticking. Mine is being replaced now by my dealer under warranty.
2020 F3 Ltd
Spyderpops Bumpskid
Spyderpops Brake/Run/Turn Signal LED's
Lamonster Garage LED Fog Lights and Headlights
2013 ST-S retired 1/9/16 at 25,061 miles
2015 F3S sold at 77,565 miles.
Thanks for posting.
was on a trip, dealer in S Dakota said bulletin says replace switch and some bracket but he didn't have parts I couldn't wait a week for them so I took it to my local dealer, they are looking for bulletin
I don't remember the actual bulletin or it's number have ever been posted on this board before. It has been mentioned in another thread that one exists. Tell the dealer to look again. It will be there in BOSS web.
2018 F3 LIMITED
My dealer in the UK told me there's an 'official' fix that simply involves taking a few mm off the rubber bumper that the brake pedal rests on with a Stanley knife.
That is for units that have the problem brand new. Pulling up on the pedal will turn the light off. When it happens a year later it is a different cause. Pulling up on the brake pedal does not turn the light off.
2018 F3 LIMITED
mine is sticking. if you tap the switch with your foot it goes out.
there is a Technical Svc Notice (TSN) I think it is called. not a TSB tech svc builletin or a recall.
it depends on your build date of your ST if they replace also the plate.
2013 Yellow ST-S SM5, Elka Stage1 Rear Shock, 2Brothers Exhaust, K&N Air Filter(soon), TricLED fnt fender LEDs, frnt LED daylight strips, 3rd Rear brake LED, ISCI Hand Brake, BajaRon Sway Bar&Links, Bullant Laser Aligned, Lamont's CAT ByPass, CALSCI Windshield, Works Performance Stage 5 Front Shocks
Previous = 2010 Blue RT-S Spyder SM5
Good comeback.
dealer replaced switch and bracket, problem solved
