14K Service
If Spyder is running Ok do the valves really need to be checked and adjusted at 14K? I have seen some threads that suggest it is not necessary. If this is not done does it void my the warranty?
2015 RTSE, Red Pearl, Shorty Antenna, Chrome Rear Rack, Deer Whistles, BajaRon Anti-sway Bar
Little checking..!!
there was a change from brp on valve adjustments but can't remember at how many miles. I have 22,000 mile and all is fine. I have seen many more. It's a choice and I have not seen any problems. They could decline on a claim if you had major valve problem and they could prove it was from not having the valves adjusted. Have not seen it and Would not do the valves if they are quiet...jmo
2012 RS sm5
Just Had Mine Done
And it was some kind of expensive, they changed the spark plugs and adjusted the valves. I can tell you tat mine was running fine too. But now my mileage has increased by maybe 5mpg.
I have mentioned in the previous threads:
Did the 2008 at 14K and no adjustment necessary.
Did the 2010 at 28K and no adjustment necessary.
Cost $1500 or so total for both. Benefit: None
Will it void your warranty is a good question.
THX all Think I will wait till 28,000miles which will probably be early next year. Rotax is a proven I engine would not think it would need a valve adjustment at 14,000 miles. The rest of maintenance I can understand the need. I think some of the maintenance is for the benefit of the dealers not because it was really necessary, but that's Ok I guess.
I also posted this in the Spyder General Discussion. I just had my 14,000 mile service done at Columbia Power Sports, Columbia, SC. The cost was $649.13 including oil change. FYI
2013 RTS SE5
2013 Kawasaki Vulcan Nomad 1700
If you don't have the valves checked at 14K and later you have something happen that involves a valve problem, you wont be covered! So while most people that had the check done found that no shims (adjustment) was needed, you take the risk by not doing it.
Now here is my judgment on this.
My extended warranty runs out Jan 2016. I figure I will hit 14K about 6 months from now maybe sooner. This will leave about 1 year left on the warranty. I think I will pass on the valve check as if I do have a problem later by not doing it (and it did need adjustment) I will probably be out of warranty then anyway.
So I would make the call on doing it based on how much time you still have on warranty and how many miles a year your putting on.
Bob
2011 RT-S SM5 - Black
My 14,000 mile service included checking for valve adjustment. They did not need to be adjusted.
2013 RTS SE5
