Results 1 to 20 of 20
    Active Member Biggdogg22's Avatar
    May 2013
    Chesapeake, Virginia
    Default 2014 RT Front Tires Replaced
    After a few days of riding my new 2014 RT. I notice the front tires riding unbalance. I mean the entire front-end is shacking. So I took the unit back to the dealer. They balance tires, etc. Still no change in tires. So they call BRP. Guess what? BRP said they got several hundred lots of tires that were manufactured with defects. They told the dealer to replace my tires. If your 2014 bike is not riding correctlyplease have them checked. BRP has no plans to issue a recall or maintenance repair notice.
    Default Good to know..!!
    murmurs have been around and your not the first. You are right those with problems should have it checked at the dealer before spending on fixing it themselves with alignments and swaybars. Once the ryde is good they can have the handling mods done. If they don't they will bad mouth everyone because it did not fix the problem....
    ​2012 RS sm5
    Apr 2012
    Columbus, Ohio
    My 2014 RT is in the shop as we speak. Tires were balanced, still isn't correct. I took it back and said call me when its right. Front end shakes like crazy between 40-60. After
    60 it smooths out. Hoping it is a tire issue. It had major shaking from mile number 1.
    None of my other Spyders had any issues what so ever, so this is all new to me.
    Aug 2013
    Quebec City, Quebec
    Quote Originally Posted by R30SHIRE View Post
    Bad tires. My friend had the same problem with his 2014 RTS. BRP replaces front tires. No charge.
    May 2013
    Quote Originally Posted by Biggdogg22 View Post
    Spyder's, got my bike back from the dealer today with the new tires installed. She now rides really smooth. So the tires were the problem. If you own a 2014 Rt have your tires checked. BRP is replacing them for free along with alignment.
    Active Member wd8ajj's Avatar
    Jul 2014
    Las Cruces NM
    Default Tires?
    With all the comments on the rear tire lasting only 6K and now the front, sounds like they bought a garbage tires from a garbage company!
    Wonder if it's smart to just put on Goodyear or Dunlap's on it.
    May 2011
    Ocala, Florida
    2014 RT Limited was pulling badly to right. Had laser alignment done to no avail. Two dealers working on problem. Finally BRP ask if I would switch the tires and wheels as a unit (without changing the tires) and see how it handles. This cured the pulling issue so BRP replaced both front tires under warranty and all is well. Also had wheels/tires balanced by the Hunter Road Force Balance System and front end is smooth as silk.
    Registered Users Jedye's Avatar
    Jul 2013
    Picayune, MS
    Bringing my 2014 RT-Limited back to Hattiesburg Cycles on Saturday. Still some slight vibrations after getting an alignment but my biggest issue is the squeaking. It sqeaks BAD when slowing down, no foot on the brake. I don't know if it's the calibers sticking or what... but it needs to be fixed. There's also a "voohm, voohm, voohm" (<---- typing my sound effects.... Don't try this at home, kids. I'm a professional) sound constantly coming from the left tire... like something is rubbing.
    New tires, new brakes, new calipers... I don't care what they replace.... but something has to be done.
    Registered Users mtdoragary's Avatar
    Jul 2010
    KILLEN, AL
    Picked my RT Limited up today. Front end shook for entire 2-1/2 hour trip home.
    3:16
    Active Member Maxson's Avatar
    Feb 2014
    Saskatoon, Saskatchewan, Canada
    Default Lucky I guess
    I picked up my new Rt a little over a month ago and have put 2500 kms. on it. I love it and the ride has been confidence inspiring including a couple of moments that would be considered illegal in most locals. I guess I'm one of the lucky ones.
    2014 Black RT SE6 - OEM backrest, fog lamps, & led light kit
    2012 NC 700XA (sold)
    Jun 2010
    Las Vegas
    We did an alignment on a friend's 2014 RT and we tried and tried but no matter what we did it pulled to the right. After we left he took off the wheels and swapped them from right to left and the Spyder pulled to the left. His dealer found a bad belt in the tire and they replaced them.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Quote Originally Posted by mtdoragary View Post
    Dealer should have prechecked and road tested your machine. Let us know what happens here.
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    True, but they could have just ridden it around the block a couple of times without going on the highway. I suppose it's a fine line between proper road testing and putting too many miles on it and ticking off the buyer.
    2020 RTL SE6
    Quote Originally Posted by wd8ajj View Post
    But remember: There are only two current tire manufacturers producing tires in the size that we need, that are makrked as suitable for motorcycle use...
    And the BRP folks can't just stick a tire on the bikes, that'll make the Feds nervous...
    Jul 2010
    KILLEN, AL
    Yep, while under warrantee they are limited in choices. But once the tire warrantee expires, good car tires are going on. There is no reason to put motorcycle tires on a vehicle that doesn't lean.
    3:16
    I've had good luck with the Kendas up front; but have always gone to rear tires designed for use on automobiles...
    Invalid Emails
    Ormond Beach FL
    They make tires for cars, light and heavy trucks too. In case you have forgotten!
    Actually a MC tire on a Spyder would be the waste of a set of good tires until you wore the centers down to the cords.
    Default FRONT TIRES FOR ...BASIC RT
    This is posted elsewhere but if you missed it ...........These tires are Freakin awesome ........stick like glue..........Toyo Proxis 185/55-15... T1r..V- speed rated and $ 57 each at Tire Rack.com.........your welcome .......Mikeguyver
    Very Active Member DR Buck's Avatar
    Apr 2012
    Fauquier County VA - Virginia's most carefully pronounced county.
    This tire problem is not new with the 14' models. Do a search on the forum. You'll find is has been going on for several years. After 3 months of trying to fix the problem I threw out my tires and went to car tires on the front. Been problem free for 10k miles.
    2012 RT Limited - Pearl White
    My Mods -
    http://www.spyderlovers.com/forums/showthread.php?39494-DR-Buck-s-2012-RT-Limited-Mods
    2012 RT Limited , Full size brake peddel White w/Red Highlights
    GOS member (Girls On Spyders) currin20fan's Avatar
    Jul 2011
    Beaufort, SC
    Default Front tires
    I have the 2011 RT limited and need to replace my front tires. Any recommendations?
    2015 RT Limited , intense Red Pearl
