Results 1 to 7 of 7
    Jun 2014
    Northridge, CA
    Unhappy Dazed and Confused.
    I've been reading about the heat issues. And, I getting ready to start working on my 2013 ST-L. My question is, does removing the catalytic converter solve the heat issue. If I do the PitBull bypass, is there no need for JT's air filter.
    I know, I know. . . Do both. But my wallet says only one at a time.
    After the heat issue is solved, then I can give BajaRon a call.
    So far, my second childhood is better than my first.
    Bryant, Arkansas
    Quote Originally Posted by Mcubed45 View Post
    The cat bypass is a major heat source so i would tackle that one first and then judge whether or not you need additional relief.
    Cruzr Joe
    Default Have to agree..!!
    JT's air box opens up the air space and improves performance but the cat removal will get the big heat out. Then when possible do the rest.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Apr 2011
    GREENVILLE, SC
    Default RESTRICT
    THE CAT RESTRICTS THE AMOUNT OF 'GASES' THAT CAN PASS THROUGH IT.....
    IT MAKES NO SENSE TO ADD ANYTHING PRIOR TO THAT.... THE ENGINE WILL NOT BENEFIT FROM TOP-END IMPROVEMENTS, UNTIL THE BOTTOM END IS ALLOW TO FLOW BETTER.....
    LOOK AT IT THIS WAY: IF YOU CAN'T POOP (EXHAUST), YOU'RE NOT GOING TO EAT MUCH (INTAKE)..... ARE YOU?
    DAN P
    EASLEY, SC
    SPYD3R
    Jun 2014
    Northridge, CA
    Default Thank you all!
    Your advice makes sense. Now I know what I'm going to do. . . (Hey, Mr. pit Bull!)
    Quote Originally Posted by SPYD3R View Post
    Look at heat wrapping your exhaust. That will be very inexpensive and makes an appreciable amount of difference in engine compartment heat.
