02-10-2015, 09:44 AM
#301
Originally Posted by spideybuffal0
Thanks for the tip all. I emailed BRP on Friday about my ST panels and I all ready received a email back today (Monday). They gave me a case # and are sending it to my dealer. They said if I don't here from my dealer in a few days to call them and give them my Case #. Pretty happy with the quickness of getting back to me.
you are going to love your air flow panels. I've had mine for a year now and they're wonderful. We did a 5,200 mile trip this summer with no heat problems whatsoever.I was one of the first three to have brp pay for and have my panels installed. At the time we could not go through my dealer, except to establish a problem, that was a must. I had to go through brp care. After a few stops and starts they set me up with a care representative and he took care of the whole thing for me, it was great and they did a wonderful job. Make sure to let us know how you like them.
02-12-2015, 06:54 PM
#302
New Airflow panels for 2013 ST-S
Hi all, new to the forum and the Spyder. I have dreamed of getting one for many years and I lucked into one. A 2013 ST-S SE5, Circuit Yellow with 3 miles on it. The previous owner had it ordered and shipped to his house then never drove it. Problem is it looks like I need the same Air-Flow Panels that all of you have. I am the second owner, even though the bike was never driven, they consider it used. Not sure if they are going to honor the warranty replacement of these or not. Any advise from the people that have done this already that might make it go a little smoother.
02-12-2015, 07:40 PM
#303
Ask a dealer if they would help you have it covered, if not buy the panels.
....and the panels aren't the be all cure all. There are some things that make a bigger difference if you are mechanically inclined to dig deeper.
03-16-2015, 05:37 PM
#304
Can you give some clues where to dig?
03-16-2015, 07:35 PM
#305
One of the biggest differences was removing the factory air cleaner and related parts. And replace it w/a JT Air cleaner http://gnipsel.com/spyderstore/index...tegory&path=64
The factory air assembly covers the whole front of the motor...1) Holding in the heat, and 2) blocking airflow.
Second biggest thing was once the air cleaner is done, move the fuel canister up and forward...it stops any unwanted fuel smells caused from boiling out the gas in it.
Third is adding some heat shield around parts such as the fuel tank and behind panels near your feet/legs.
Yes some say you shouldn't have to do these things and some claim they don't work...but they all worked on my ST-S and I got to know the bike more in doing so.
05-26-2015, 02:16 PM
#306
05-26-2015, 02:21 PM
#307
05-26-2015, 02:22 PM
#308
Originally Posted by bscrive
Those are the original panels.
New ones look like this:
Thanks
05-26-2015, 02:28 PM
#309
05-31-2015, 03:19 PM
#310
06-02-2015, 08:03 AM
#311
06-02-2015, 08:31 AM
#312
Unfortunately, you will have to go back to your dealer and insist that the new panels are put on. I believe that they will do some checking to satisfy BRP and then request the new panels. If your dealership won't do anything then I would suggest contacting another and do your business there for now on.
06-02-2015, 09:58 AM
#313
I just heard back from BRP, they explained to me what they were trying to say was that any authorized Spyder dealer can help me. I am still waiting to hear from the dealer I where I purchased my Spyder (100 miles from home). If I get no satisfaction from the purchasing dealer then I will attempt to find a dealer willing to help. I am having the BajaRon sway bar installed at a dealer closer (30 miles) to home. Ron recommended this dealer as they have installed a lot of his sway bars.
06/07/2015 - I have heard back from the dealer, they are ordering all the parts necessary to fix this problem. Now it is just waiting until all the parts come in. The service manager did tell me the job is much more than just replacing the outer panels and it will require 1 mechanic a full day to complete the work.
06-04-2015, 09:39 PM
#314
replacement kit
My BRP dealer told me today that BRP is not issuing new panels but a kit that has to be installed in the old ones. Has anyone had the "kit" installed? How does it look? Do they eliminate they heat on the right foot/leg?
Thanks Donna
06-05-2015, 07:54 AM
#315
Thanks Donna
This kit includes the panels.
Helps, but not a total cure.
06-05-2015, 07:55 AM
#316
The STs get new panels...
The RTs, are getting scoops installed on their existing panels.
There may have been some confusion about the model of bike being discussed.
06-07-2015, 05:12 PM
#317
My STS is at the shop
Well guys, I finally got a case number from BRP and drop off my STS for diagnostic test. Its been a week. Im assuming there is some progress going on. This week I should here back from the dealership hoping for good news on my heat issue. Will keep you all posted. Im still amazed that after all the STS owners have complained about this heat issue, there still isn't a recall but I guess BRP rather deal with the issue only if we complain about it.
06-13-2015, 11:16 AM
#318
06-13-2015, 11:38 AM
#319
06-13-2015, 12:29 PM
#320
Originally Posted by ingramwc
I also go newly designed the 'airflow panels' that are on the 2014 ST's. They do form a (sort of) scoop but nothing like is on the RT. I'm not sure why they told you "no new panels" because that's exactly what they are ... a new design. And you'll definitely enjoy the end to the heat problem - your engine components will thank you too. I've had my panels for almost a year ... they rock.
06-13-2015, 12:33 PM
#321
06-13-2015, 12:39 PM
#322
The engine temp has nothing to do w it.
Its concentrated heat that you feel through and around the panels mainly blowing/radiating to your legs and feet. If it's unbearable "at times", then you have it.
The engine temp has everything to do it - lack of air flow is the problem ... all that heat had no place to go until they installed the 2014 Air Flow Panels on my ST. My panels got up to 182 degrees at one point. Now they are a reasonable temp.
06-13-2015, 12:40 PM
#323
06-13-2015, 03:59 PM
#324
2014 ST/RS panels are not being used anymore! If you already have the new panels, then you got lucky. 2 dealers told me that heat issues will be fixed under the new procedure that was just released 05/26/2015 by BRP. That's how my problem is going to be fixed, that is all I know. I am not making this up. There are pictures of the new scoops on another thread, but I do not remember which thread. This is not my opinion, just what I was told. I get no thrill out of spinning BS!
Update:
Here is a link to a thread of an RT with the new scoops: http://www.spyderlovers.com/forums/s...3-RT-Roadsters
If the dealers are BSing, why would 2 dealers over 100 miles apart in 2 different states have the same story? Just my $.02.
06-13-2015, 04:06 PM
#325
You may be correct in what you have been told by the dealer, but I don't see how the scoops that are being put on the '13 RT's would fit on the ST and RS's. BRP is still making the new panels because they come on the '14 and '15 ST's and RS's. They will easily fit on the earlier ST's and RS's. I think the dealer is full of BS.
2020 F3 Ltd
Spyderpops Bumpskid
Spyderpops Brake/Run/Turn Signal LED's
Lamonster Garage LED Fog Lights and Headlights
2013 ST-S retired 1/9/16 at 25,061 miles
2015 F3S sold at 77,565 miles.
