Results 1 to 9 of 9
    Active Member NovaSpyder's Avatar
    Apr 2013
    Nova Scotia, Canada
    Default BRP trailer wiring harness
    Does anyone have the part numbers and/or cost for the BRP trailer wiring harness (3 pieces)? I have a 2014 RTS with hitch sans wiring and a 2012 622 with the 4 wire square plug. Weighing my options, looking at the big bike parts harness as well. I do not want to make my own. I've read over 50 threads on the subject, lots of opinions
    Dan
    2014 RT-S SE6, 2012 RT-622 trailer
    Invalid Emails
    Jun 2014
    Edmonton AB Canada
    Default BRP Parts
    I am looking in the 2014 catalog, and see
    4-PIN Trailer Adaptor Harness
    Designed to convert 2013-2014 RT-622 trailer's electrical harness into a standard 4-pin trailer connector for automatic use.
    RT-622 2013-2014
    219400437
    $74.99
    RT-622 2012 and prior
    219400271
    $164.99
    There is also the RT-622 Tongue Harness
    Converts 2011-2012 RT-622 trailers for compatibility with 2014 hitch and module (RT and ST), and 2014 4 pin adapter.
    RT-622 2011 to 2014
    710003227
    $44.99
    Chas
    Active Member tnhoover's Avatar
    Jul 2010
    York Pa
    I also had the BRP hitch sans wiring harness. I went with the trailer power isolated kit fro Big Bike Parts although I bought it through value accessories who I believe is a site vendor here. It was a pretty easy install and the guy from Value Accessories answered all my questions before I bought. Once you install you end up with a 5 wire cable you have to attach a coupler to. If you are going with the standard BRP trailer I beleive you can buy that piece from them as well. I was wiring for a 4 wire flat trail so I used a Hopkins converter to go from 5 wires to 4 and then put a 4 wire flat coupler I got at Wal-mart on it. If I can answer any questions about what I did PM me and I will send you my phone number.
    Apr 2013
    Nova Scotia, Canada
    Quote Originally Posted by ChasCS View Post
    RT-622 2013-2014
    219400437
    $74.99
    219400271
    $164.99
    RT-622 2011 to 2014
    710003227
    $44.99
    Chas
    Thanks Chas, i looked at those but I don't think that is what I am looking for. They are for the trailer "end" I think but I am looking for the wiring and module that connect underneath the tupperware.
    Dan
    Apr 2013
    Nova Scotia, Canada
    Quote Originally Posted by tnhoover View Post
    Thanks for the kind offer. If I go that route, I will PM you.
    Dan
    Invalid Emails
    Jun 2014
    Edmonton AB Canada
    Default Call the dealership for part numbers
    http://www.brp.com/en-ca/customer-service
    How can I get support for a part or accessory?
    Please get in touch with the Parts department of the dealership where you purchased the part or accessory.
    Or Call us: 888.272.9222
    Chas
    If the parts guy at the dealer is the cooperative type he can look up the install instructions for the BRP hitch kit. It will list the part #s for all the pieces.
    Oct 2007
    Default New F3 trailer harness on the 2018s
    I'm having trouble finding the new trailer harness for the F3 T 2018. It is not on eBay and can't seem to find it on BRP accessories. I think the part number is 71000634 but not sure. Can anyone direct my in the right direction?
    Thanks.
    Hi there,
    Have you figured out your question about a harness for F3 T 2018?
    I installed a Can-Am hitch but would like to get a non-Can-Am trailer. Where can I find an adapter between 4-flat and Can-Am's 4-square?
    https://theusatrailerstore.com/foldi...or-motorcycle/
    https://theusatrailerstore.com/rally...cycle-trailer/
    Many thanks!
