iPod Integration Cable
I just got an iPod integration cable for the trunk (thanks Stevedfive). Looks like there isn't enough power to properly charge an iPad. The iPad reads "not charging" though a Google search says that when it's in sleep mode, it is actually getting a slow charge.
So here is my question. Does the cable drain any battery power if it is left in while the Spyder is turned off (whether it be plugged into an iPod, iPad, or just left unplugged except at the multipin connection)?
Michael
You call it a midlife crisis. I call it all the things I wanted to do!
2010 RT-S SE5
I keep my old iPhone 4s plugged in at all times with no issues.
2017 F3- Limited
F4 23" Windshield, Ultimate Backrest, Spyder Cuff, SpyderPops Bump Guard, Sena SMH10 Intercom, BajaRon Sway Bar, Baker Cup Holder, RT-622 trailer w/Spyder Pops Bump Guard
, I KEEP MY IPOD CONNECTED ALL THE TIME
cRUZR jOE
My IPod is velcroed into the trunk and stays in for the riding season. No problems for me, it's always fires right up.
The iPod cable is only powered when the key is on. Power to that cable comes from the radio. So if you let it sit long enough your iPod, iphone, iPad whatever will eventually power off due to dead internal battery. This is OK because most I-devices will power back on the minute they get power through the connector.
Bob
2011 RT-S SM5 - Black
iPad/iPod IPhone
Bob
I have all three. And they charge without problem....I keep the iPod in all the time....but have used the other 2 also
The little Saltine Cracker" that I've got back there; just seems to keep on truckin' Keep On Truckin.jpg
where to buy ipod cable connection
Looking to buy a new ipod connection cable for spyder rts some place cheaper than can am
thank you
rock n roll
I've not seen any significant discounts, and nobody has an alternative; the plug end is BRP-specific...
Like the rest of the group, I just put an old iPod in the trunk and forgot about it. It always works...
That is not correct. It's a standard DIN plug you can buy off the shelf! Same with the iPOD connector.
If you have a older Spyder then YES it has that black box in the cable which is BRP specific.
However if you have a late 2012, 2013, or 2014 then you can make your own iPOD cable from off the shelf connectors. Roger posted the DIN plug wiring to the radio several times. So you can make your own cable for probably less than $10.
Bob
