10-02-2014, 06:45 AM
#101
Originally Posted by Doc Humphreys
I am home now and have the Napa kit ($15) in hand. Should have some good info on the BRP oil out of my RT by mid-week next week. That oil has almost 4,000 miles on it. Interested to see what the shearing has dropped to. Will also have them check for contaminants including any metals. I'll post the results when I get it.
Sounds good Doc. Been wanting to see a lab report on the BRP Blend for some time as I've never used it.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
10-02-2014, 08:02 AM
#102
I cannot find the weight on the BP container. All it says is summer blend. I am thinking it is 15-40 or 15-50. Need to know before I send it off. It is the BRP semi-synthetic from the dealer. Anybody know for sure?
10-02-2014, 09:05 AM
#103
BRP parts guy called back and said it was 5-40. That is what I put on the form.
10-02-2014, 09:46 AM
#104
The parts guy is correct.
2018 F3 LIMITED
10-02-2014, 03:09 PM
#105
Originally Posted by billybovine
It would be interesting to know who packages the oil for BRP. I know of only one company, right off the top, that makes a 5-40 BLEND and thats Bel Ray. May be others but this is the only one I know of. Several make full synthetic in 5-40. Is this the same stuff that comes in the kit for 998's?
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
10-02-2014, 03:53 PM
#106
So you don't believe BRP's marketing dept. that after years of research and millions of dollars in expenses. They created their own blend of engine oil.
http://xpslubricants.com/news_detail_allprod.asp?id=2
2018 F3 LIMITED
10-02-2014, 04:32 PM
#107
10-02-2014, 06:41 PM
#108
2018 F3 LIMITED
10-02-2014, 06:43 PM
#109
2010 RTS-SE, Orbital Blue
I was at my dealer one day when he got an oil order, it came on a Castrol pallet.
10-02-2014, 08:04 PM
#110
DO YOU REMEMBER THIS
That's what BRP says. Of course they don't make their own oil. Of course they would have hired some other company to do the development. But they claim it cost BRP 2 million dollars and 3 years to develop their line of engine oils. So if you believe what BRP says. They are not sticking a different label on someone elses jug.
I am just repeating what I have read. Believe what you will.
Billy back in the beginning BRP used to say " if you don't use FULL SYNTHETIC " the Spyder will self destruct .....Yes that is an exaggeration, but they haven't changed anything in their metallurgy in the engines to make them a lot stronger so you can use inferior ( read that as BLENDED ) OIL.......They having someone create an oil to their specs and they are putting their name on it .......And they are not the only company that does this .............Just sayin.....Mike
10-02-2014, 09:38 PM
#111
I have to agree with Mike on this. Napa sells their "house oil" that is actually Valvoline in the bottle under their label. I would venture a guess that BRP spent all that money finding the best blends, then hiring someone to bottle it under their name. I see nothing at all wrong with them doing that. And I think their oil is great. Unless this oil report shows me something that I don't like, I will probably continue with their oil, regardless of who blends it for them.
10-02-2014, 10:45 PM
#112
Had 1 dealer say i needed to change oil at 600 miles for RTS 2014>>>>another dealer told me 3000 miles>>which one is correct????? Do all dealers charge same amount of money on 1st maintenance?? Thks in advance
2012 RT Limited Lava Bronze
Inspector Gadgets cupholder & rear deck brake light
10-02-2014, 11:14 PM
#113
WHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAT
10-03-2014, 05:54 AM
#114
A while back it was generally accepted that Castrol was the supplier and that the summer BLEND was a 10-40 and the winter SYNTHETIC was a 5-40.
Castrol is one of the few that make a motorcycle synthetic in 5-40. However, not long ago when I mentioned the above, someone (forget who) corrected me and said BRP had changed their supplier a couple years ago. Thats why I mentioned Bel Ray above.
How long ago was it that you saw the pallet of Castrol?
Do I believe BRP makes their own oil? Absolutely not!
Do I believe they spent a million or so developing it? Absolutely not...marketing hype is the name of the game.
How will we know how good their Blended oil is? When DocHumprey gets his lab report back, that will go a long way to tell us what the quality is. If it comes back showing the viscosity is still 40W or near that, I'll post an apology to everyone and beg BRP's forgiveness for doubting them!
Furthermore, I'll provide a prepaid test kit to anyone who does their own oil changes and has 9000 miles on the Blend if they will send it in and post the results here.
You'll need to get the sample immediately when it starts draining (not out of the drain container as that would be contaminated), or preferably siphon some out with a clean hose.
Any takers?
PS: I'm not knocking BRP oil. I'm saying that I firmly believe that NO approved motorcycle oil, whether its Blended, full synthetic, or Dino, will make it to 4000 miles maintaining its viscosity of 40W in either the 998 or 1330 motor.
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
10-03-2014, 08:42 AM
#115
2018 F3 LIMITED
10-03-2014, 09:51 PM
#116
So what about full synthetic being to slick for the clutch? Or is that a bunch of ?
10-03-2014, 11:38 PM
#117
HOOEY
.....I've been using Rotella 5 W/ 40 full Syn in my 2014 RT and have not had any issues in the past 4500 + miles .......Note this OIL is only certified for the 1330 Ace engine ....Mike ......................................PS...for you bargain hunters , this sells for about $23 per Gal @ Walmart
10-04-2014, 07:50 AM
#118
Its a bunch of Phooy as long as the oil is motorcycle certified.
BRP still sells the synthetic as far as I know, and you've got
Amsoil, Valvoline, Castrol, and a bunch of others. Take a look
here for cycle oils:
http://www.powersportsuperstore.com/...-Oil-s/283.htm
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
10-04-2014, 08:01 AM
#119
I am considering going to Castrol T4 5W40 full synthetic motorcycle oil JASO-MA-2 API SL rating... anyone else using this in their RT ?
10-09-2014, 06:58 AM
#120
Sample
I hope the lab didn't lose my oil sample. It was only going one state over. Maybe tomorrow......
10-09-2014, 07:31 AM
#121
Doc, I've had them take up to two weeks, but usually its much quicker. Should have it sometime this week...hopefully.
In case you don't have this, here is a viscosity chart for you:
http://www.bobistheoilguy.com/viscosity-charts/
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
10-09-2014, 09:59 AM
#122
10-12-2014, 04:20 AM
#123
Amsoil
Originally Posted by PW2013STL
From the report you should be fine as it looks like a quality oil
Amsoil is not a full synthetic it is 100% synthetic.Does anyone in really know the difference between the full and the 100%?
10-12-2014, 04:24 AM
#124
Originally Posted by bgame
SYNTHETIC OIL MYTHS
Myth: Once you switch to synthetic oil you can never switch back. This is one of the most persistent myths about synthetic oil—and completely untrue. You can switch back and forth at any time. In fact, synthetic blends are simply a mixture of synthetic and conventional oils. It is advisable that you use the same oil for top-ups if needed, thereby giving you the best protection from the oil that you have chosen.
Myth: You shouldn’t use synthetic oil in an older vehicle. The myth is rooted in the idea that synthetic oil is “slipperier,” lower in viscosity, or not as compatible with seals and will therefore leak or leak more in places conventional oil might not. Again, completely untrue. Synthetic oils will enhance the engine protection in older vehicles just as they do for new engines.
Myth: You should break in your engine with conventional oil before you start using synthetic oil. Again, there’s no manufacturer we’re aware of that makes this recommendation. Mercedes, Porsche, Corvette, some Cadillacs, Volkswagen, Hyundai and many other manufacturers’ cars come from the factory with synthetic oil.
Myth: Using a synthetic oil voids a car’s warranty. Untrue. The only engines that specifically exclude the use of a synthetic motor oil are some Mazda rotary engines.
Myth: Synthetics made from Group III base oils are not true synthetics and are not as good as PAO-based synthetics in Group IV. Again, untrue. Synthetics made from Group III oil can, in some cases, outperform those made in Group IV oils in some areas of performance.
Maybe some one has learned something from your post..
10-12-2014, 04:32 AM
#125
Mobil 1 vs. AMSOIL Independent ASTM Certified Laboratory Testing
Mobil 1 vs. AMSOIL
Independent ASTM Certified Laboratory Testing of the new Mobil 1 Extended Performance vs. AMSOIL (and nine other major brand name motor oils) has been completed. AMSOIL is the clear winner.
Mobil 1 EP Evaporates 38% Faster Than AMSOIL, Mobil 1 EP Allows 18% More
Cold Start Friction and Mobil 1 EP Allows 22% MORE Wear
In addition, on the TFOUT test, the "Thin Film Oxygen Uptake Test" (ASTM D-
4742), which provides a very good correlation to the drain interval
capability of an oil, AMSOIL passed the 500 minute cut-off mark with flying
colors and still going strong, while Mobil 1 fell
short at only 469 minutes. Once again, we say that Mobil 1 is a good
quality product, however it does not compare to AMSOIL and the test data
clearly shows this.
