Originally Posted by MarkLawson
Early SpyderLover posts suggested Mobil 1 (motorcycle) cause permanent clutch damage on the Spyder. I don't know if that is still the case, but wanted to throw this out there.
Most likely they were using the auto formula. I have never had an issue with the motorcycle formula and clutches.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
RT-S PE#0031
Mark & Mary Lou Lawson
Snellville, GA USA
'10 RT-S PE #0031
'10 RT-622 Trailer
'08 Yellow SM5 #2332
'01 Black GL1800A Goldwing #0930
"Remember in the darkness what you have learned in the light." - Joe Bayly
If Scotty said it; I'd believe it!
Interesting read.
Looking at my owners manual is states "SL, SJ, SH, SG, or higher" Nothing about "API SM rating, which is expressly prohibited by BRP"
Mobil's web site states "According to ExxonMobil, Mobil 1 Racing 4T 10W-40 is of the following quality level:
API SH
API CF"
Great report. Thanks for posting it. I was concerned too.
Thanks..!!
glad there are those testing things out. Brp must have run some tests upping the 998 oil change 1,600 miles to every 4,600 miles. But good to know the 1330 spec's are close according to your report...
2012 RS sm5
Originally Posted by PW2013STL
Thinking 9300 miles between oil change is a bit to long I changed it at 6000 miles (9000 on the Spyder) and sent a sample to Blackstone Labs to be tested. Received the report yesterday. Everything came back positive and with a recommendation to wait until 8000 for the next change.
Looks like BRP got this one correct
I changed over to Mobil 1 10-40 and will wait the 9300 miles and have it tested again
Please post this in the break in thread which started yesterday. We specifically had a question as to whether or not we wait 9300 miles after the break in service or just do the oil change at 9300 miles and go from there. I like to err on the side of conservatism, so suggested I would be doing my next oil change at 9300 instead of 12,300. Now, it looks like I will just go with my annual start up oil change service at the beginning of every riding season, unless I exceed the 9300 mile limits.
Thanks for posting your results.
Interesting read.
API SH
API CF"
There appears to be a mix up of requirements for different engines. All owners manuals for all Spyder models and all years for the 998 engine have a warning not to use any engine oil with an API rating of SM. Serious clutch damage will result. The owners manual for the 1330 engine has no such restriction. Since this discussion is for the 1330, SM rating is mute.
2018 F3 LIMITED
For those who want to use Mobil1 4T, Advance Auto has it on sale for $8.98. It may be ended by now...not sure.
I've always been concerned that its just MA, not MA2, but obviously a number of riders are using it with no clutch issues.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
I have been trying, but so far no luck. The number for that is 8.36 and the range is listed at 6.0-9.7
I'm really puzzled; at 8.36 the viscosity has dropped down into the 20W zone, according to: http://www.bobistheoilguy.com/viscosity-charts/
To further confuse me, a major lab I've been using, ALS, reports numbers in the 11.6 and below as "caution" and once I got a 10.1 and they flagged it "danger".
The question I've never been able to get answered is how low can the viscosity shear down to and still be viable?
Obviously, the two labs have different views, and BRP says 9300 miles is good. Have to admit, Blackstone's report makes one feel comfortable with whatever oil one is using.
Maybe I'll sent my next test to both labs and see what the results are.
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
To throw my hat into the discussion...
I too am a big beleiver in full synthetic oil and use it in all my vehicles.
I just had my 2014 RT-L in for it's first service and had them use BRP's full synthetic when they did the oil change.
Now I've only put about 200 miles on it since but it seems to me that it doesn't shift as smooth as it did with the blended oil. (a little more clunky)
I'm off on a nice 10 day road trip, dipping into the US for a few days (that's right, the Canadians are coming) so I'll get a better feel for it.
Just wonder if maybe it's to slippery for the tranny???
Has anyone else gone to full synthetic in the 1330???
I used Amsoil for one 4000 mile run but could tell no difference in shifting from the previous fill of Castrol Blend. Now running Rotella T (dino) with 2000 mi on it and can't tell any diff.
On BITOG forum, a lot of bike owners say they can definitely tell a difference with certain oils sometimes its dino only and sometimes synthetic, so I suppose it might make a difference.
On my previous 998 I thought it shifted smoother when I used Castrol Blend (which some say is what BRP Blend is).
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Now the my confusion is so clear to me thanks guys.
2012 Spyder RT SE5 Brake pedal mod
Baloo is my name. Spyders are my game. Well, it's a doo-bah-dee-doo, yes, it's a doo-bah-dee-doo, I mean a doo-bee, doo-bee, doo-bee, doo-bee, doo-bee-dee-doo. And, well, now. Ha ha! What have we here?
2020 Petrol Blue Metallic RTL
I just had my 14 RT serviced. I asked for full synthetic. They called and said they had none in stock. I asked for Amsoil 10-40. The reply was, BRP specifies 5-40. They do not stock the BRP full synthetic. So I ok'd the BRP semi-syn.. I have to think about what to use next time. They will NOT use anything but 5-40. Only known oil I know of is Bel Ray, and Shell Rotella. BTW my first 3,000 mile service was $231 with tax. Tom
Originally Posted by Tango
Mike is the Rotella "JASO MA or MA2"? Tom
For whatever it is worth, Wikipedia says:
JASO-MA[edit]
JASO is an acronym that stands for "The Japanese Automotive Standards Organization." Among other things, they set standards for oil to be used in motorcycles.
Shell Rotella T 15W-40 conventional oil does list on its packaging JASO MA as one of the specifications it meets. Note that the 10W-30 conventional oil does not list JASO-MA.
The newer fully synthetic T6 5W-40 oil lists JASO-MA compliance on its packaging and on the Rotella website.
I could not find this info on the Rotella website.
2013 RTS SE5
2013 Kawasaki Vulcan Nomad 1700
OIL CHANGE
If they used BRP semi-syn, its a 10-40. Walmart stocks Mobil1, Valvoline, and Castrol motorcycle oil. Heres another site if you want a wider selection of oils:
http://www.powersportsuperstore.com/...-Oil-s/283.htm
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Probably going to switch to Mobile 1 for my RTS next change, too. Glad you ran the analysis on it! Good info. Where is everyone buying their oil filter kits for the 1330? Is the dealer the only place?
I am sorry you are incorrect BRP Blended is 5W-40 it has not been 10W-40 since the new formula was phased in in 2008-9. You're 5 yrs behind.
2018 F3 LIMITED
Good to know. Thanks Billy.
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Went to Wally World today. Checked out the Rotella T6. $25.50 for a gallon. Good price. Tom
