Results 1 to 10 of 10
Thread: Odyssey Battery
    Jul 2014
    Deep South
    Default Odyssey Battery
    I have a new 2014 RT Ltd. The battery seems not to hold a charge. Does anyone know the part # of the proper Odyssey battery for the 2014 RT that will replace the OEM YUASA? I have had good experience with Odyssey batteries in the past. Thank you for your responses.
    Sep 2013
    Houston
    Quote Originally Posted by rgk View Post
    Your battery is under warranty, let BRP replace it. Should not have any trouble staying charged and YUASA is a good brand. Should last at least 2 years on the bike before you need to worry about it. and the 2014s have a much better charging system.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    May 2013
    Hollister,Ca.
    Have the dealer check for any issues before buying an expensive battery.
    2011 RT LTD. Pearl White
    Jul 2014
    Deep South
    Default Battery Drain from Radio
    Quote Originally Posted by Rattigan_Roger View Post
    It's PC-680 Odyssey but I would do a few things first before I replaced the battery.
    1. Check connections and make sure they are all clean and tight.
    2. Key OFF. If you have access to a Digital DMM remove the ground connection and place the DMM between ground and the battery terminal. The polarity of the reading is not important. If it reads over 200 mA you have a drain on your system probably from the radio.
    Batteries are not perfect and one could escape from the factory that is defectrive but there is a higher likelyhood that something else is wrong.
    How does one end the drain from the radio? Thank you.
    Default Agree..!!
    yuasa has always been good. Have the dealer check it out and replace it if bad or fix the drain to it if one is there. You should not have to spend you money on a new one yet. They last from 2 years on up...7/8 years have been seen....
    ​2012 RS sm5
    Jul 2014
    Deep South
    Default Radio Drain on Battery
    by going to the dealer
    Is there a fuse to disable the radio and end the drain? Thank you.
    Very Active Member IGETAROUND's Avatar
    Oct 2011
    Kalamazoo, Mi
    perhaps a look in you owners manual, or an online source might direct you to the proper spot.
    All the great movements in the world began with a cup of coffee!
    2018 F3-T
    My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
    2018 F3-T , Pearl White
    Active Member condorflysu's Avatar
    Feb 2013
    Brampton, Ontario, Canada
    Odyssey are outstanding batteries....all I've had is good experiences too. Using a battery minder maximizes the life best.
    Jul 2014
    Deep South
    Quote Originally Posted by IGETAROUND View Post
    Thank you, that's helpful.
    Jul 2014
    Deep South
    Checked with DMM, checked ok, took battery to Batteries Plus, tested and found defective, bought new battery yesterday, works fine now. Thank you for your help.
