2008 gs/rs oil change
today I change the oil and filter on my spyder manual shift went to the letter by the book change oil and filter put in 3 quarts run it for a minute cut it off add 1 quart run it to operating temp cut it off check oil. oil only comes up to add mark on the dip stick what am I doing wrong
Ride it around for an hour and then check the oil. It must be ridden to get everything up to temp.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
oil change
I,ll try that thanks
SpyderLovers Sponsor
Typical oil/filter change on a 998 Spyder takes 4.25 quarts so I'd say you're doing it right. You just need to add the last bit to bring it to full.
Have to agree..!!
bring it up ti operating temp 4/5 bars and add as needed.
2012 RS sm5
