Results 1 to 13 of 13
    Member pamopfl's Avatar
    Jun 2013
    United States
    Unhappy 2008 GS Battery REplaced
    I replaced by Spyder battery with one from the local Can Am dealer. Got everything put back together and when I turn the key on.....nothing.....dash is dead as if the battery isn't there. Is there a video somewhere to show me if I got it back together properly?
    HELP!
    2008 GS Se5-
    Heli Bars, Corbin Seat, Corbin Smuggler Trunk. Custom Dynamics Handlebar Accents and extended Parking Brake Peddle. Spyderpops Air Management System-Missing Air Dam-Heat Shield. BajaRon's anti-sway bar. Spyderpops bumpskid.
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default WORSE THOUGHT
    WORSE THOUGHT......
    did you get the polarity correct........??????
    please check and see.... then check your fuse box for fried fuses.... otherwise i'd say the battery was not good from the start...
    Dan P
    Easley, SC
    SPYD3R
    Jun 2013
    United States
    Default Battery replacement
    Update: The lights on the front of the fenders gave a little blip when I turned the key. Still nothing on the dash.
    Maybe the battery just needs charging?? I put a battery tender on it.
    I'm fairly positive the polarity is correct. Haven't checked the fuses yet.
    2008 GS Se5-
    Apr 2011
    GREENVILLE, SC
    Default keep
    Quote Originally Posted by pamopfl View Post
    KEEP US POSTED PAM.....
    WE DO CARE...
    Active Member Spyder601's Avatar
    Jun 2012
    Brandon, MS
    I would definitely check the fuses, it doesn't take much to burn those precious pieces. Keep us posted
    17 F3 Limited (Pearl White), Sena 10C intercom, X Grip iPhone mount, IPS key, spyder to go cup holder, Lamonster Highway Center Lane, TricLED engine lights, TricLED night rider, LS2 Helmets, Lamonster Bypass pipe, 2 Brothers Exhaust, mirror relocator kit, Bluetooth radio module, OEM Backrest, Rear LED Light Kit
    2017 F3-T , Pearl White
    Oct 2007
    watsonville CA
    HELP!
    There are is 2 wires for the Pos + post, did you leave one off ?
    Jun 2013
    United States
    Default 2008 GS Battery Replacement
    Checked all the fuses (in Frunk and Under the Seat) and they are OK.
    Rechecked connections and Red/Positive with two wires connected correctly.
    Black/Negative connected correctly.
    Battery Tender shows solid red Charging light and blinking green Storage light.
    Still nothing showing up on the dash console.
    2008 GS Se5-
    Default Little checking..!!
    if you have jumper cables hook it up to the car and see if it comes to life. If it does the battery is needing a charge which a tender will not do. If it does not then there is some missing/bad connection. Could be the ignition switch or faulty ground...let us know..
    ​2012 RS sm5
    Jun 2013
    United States
    Hubby got home from being out of town. He deduced that the battery the Can-Am Dealer sold me for $153.00 has a bad cell in it. Back to the store I go tomorrow.
    2008 GS Se5-
    Keep us posted. Never good when you get a defective "new" part. The upside: The second install is going to go a lot quicker.
    Very Active Member freebob's Avatar
    Apr 2009
    Bluffton, S.Carolina,USA 29909
    Default Battery
    HELP!
    That battery is ytx24hl-bs......YTX24HL-BS High Performance - Maintenance Free - Sealed AGM Motorcycle Battery ..
    Amazon has several listing on it this is one of them in link above....Fully charged....ready to go.....I beleive Walmart also sells that batt.
    Freebob...
    Jun 2013
    United States
    Quote Originally Posted by freebob View Post
    Freebob...
    What's the difference between a "BS" and the one I replaced which didn't have the BS on it?
    Thanks
    2008 GS Se5-
    Jun 2013
    United States
    Default On the road again
    Second battery installed and all is well again.
    Thanks to all who responded and helped!
    2008 GS Se5-
Tags for this Thread
