Heat comming from under the seat in the front how to stop it
Does anybody have this problem.
Way to much heat coming out of in front of the seat
Would like to join a group from this area. Bellingham Wa
Originally Posted by akspyderman
I note this is your first post. So, what are you driving? More information will help with getting an answer.
I note you went off line within a minute of your post.
to all,,,,,, rule #1 what is your ride? I'm here in Whidbey Island.
2012 Spyder RT SE5 Brake pedal mod
check your exhaust gaskets,
Under seat heat
Yo JeffnVal,
First: What Spyder model?
Second: What type of Ryding gear? Leather? Shorts?
Third: We are in Bellingham, sent you a PM give us a Jingle
Spyderkidz
Hi Jeff,
I know what you are talking about, its cool weather from September to June in Bellingham (I am just north of you in Lynden), seldom getting over 60, but since then the heat has climbed into the 70's and 80's now and the heat that came out around the seat is horrible when I had my 2011 RT. I did fix it so give me a call and I will go over the fix with you. We have an informal club as well we can talk about.
Randy 360 815-4232
Take the seat locking post off, cover the latch area with duct tape, & ryde.
2014 RT-S SE6
Mods:
Custom Dynamics Magic Brake Strobe
Ram cup holder & mount
Ram GPS mount
BajaRon's anti sway bar & links
Spyderpop's Bump/Skid plate
Gorilla Alarm
Lamont Laser Alignment
Corbin Seat & Backrest
Luggage Rack on Trunk
Akrapovic Exhaust
Lamont's primary muffler delete
Spyderpop's missing belt guard
Lidlox helmet locks
Pinstriping by "Killer Designs by Darin"
My exhaust spring was broke n cooked the gasket / I'd give that a check
I covered mine with DEI reflective heat tape.
2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
One thing about the group I enjoy is that I have issues, snoop around a bit and find answers! Will be doing the reflective tape once I get home. Thank you for sharing the DIY fix!
heat
I have a 2014 RTS new with 500 miles. I to can feel heat coming from under the seat. I also hear a loud fan that comes on occasionally. I had chalked it up to the break in period but now I am not sure . I live in San Diego so mild climate.
I eliminated 95% of the heat and stopped the boiling tank. I used thermo blanketing that you use under the hood on cars and trucks. I cut it to fit up and over the air cleaner and down to just above the header pipe (this material is treated with flame retardant). I then took more of it and run up and under the fuel tank and taped it to the first blanket with aluminum duct tape. This forces all the heat down and under the bike instead of up and around the seat. I was carful to fit it right and it was great after that.
I then took it a step further by removing the useless small pieces on the side panels and glue the blanket to all of the side panels to cover every inch possible. I also did the lower black filler panels. this kept the heat from radiating from the panels when parked or idling.
I also blocked the side duct and insulated everything to prevent any heat getting out on or near my right foot. I remove the stone cover so the heat could be pushed down and out the bottom. An days work but it paid in spades for heat control.
Just out of curiosity, have you ridden street motorcycles (two wheelers) in the past?
Phil
I may be old, but I got to see all the cool bands.
2011 Spyder RT-AC
Have you posted a step by step of what all you did with pics etc? Id be highly interested in it please Sir. And from what i have read thus far there are a ton of others who would be as well.
Heat
I wish you didn't live so far away, cause I've got a job for you ! LOL! Going to try that on mine this week. Wish me luck !
Happy wrenhing!
