2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
Originally Posted by Knarfoh
I notice in your profile you have a 2012 RS SE5 Spyder White.
I have a 2012 RT-S SM5.
Is there something about model year 2012 that suggests the fuel tank should be wrapped?
I see a lot of that mentioned for 2013, but not 2012's.
Yes I have a 2012 RS but my friend has a 2013 ST-s. The problem with the Cool-It product is on the ST
Where's that stick , doggy beat down
Bill
2013 RSS Neutron Green
BRP HID's and Fogs
Custom Belt Tension
2014 side panels
HMF Exhaust
K&N air filter
Bajaron sway bar and links
Lol
It's only a nerf stick you'll be ok
Bill
BRP HID's and Fogs
Custom Belt Tension
2014 side panels
HMF Exhaust
K&N air filter
But...
How many miles have you ridden your ST-S so far?
Since the insulation, I think 1500-2000 miles?
Originally Posted by billrob71
Lol
Whew
You ride even LESS than I do!
2017 Chevrolet Camaro SS convertible. 2017 GMC Sierra cc diesel. 2017 Arctic cat RR 137 ES
I havent had any issue w it, and I only used it because others here recommended it.
Well I guess you need to be more selective on whose advice you follow.
Originally Posted by Tazzel
This the result
After wrapping the ST-S gas tank with the Cool-it insulation that Snoopy used it started to melt within 20min. What a mess!!!!!!!!!!!!
Yikes Snoopy! Ya could da burned down the whole dog house. Did you check the temp limits? What would a wrap temp limit be for this situation?
Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
I think that highlights the problem though of the gas tank reaching in excess of 300 degrees causing the adhesive to break down...
2017 Can Am Commander Limited
2012 Cadillac CTS-V Black Diamond
2020 F3 Limited Magma Red (miss the 2011 Viper red)
2010 RT622 - Black
Originally Posted by bruiser
I have the Thermo Tec starter heat blanket between the gas tank and seat on the wife's RTS. It works good, cut the heat under the seat. I used the Thermo Tec cool shield tape on the fuel tank and it didn't stick.
Do you have a link of the blanket you used and any pics of it installed. Ours has always had issues with the heat under the seat. Especially in the summer. Makes it almost unrideable.
2007 M109R LE - To many MODS to list. Its cheaper that way!!!
