New 2014 RT Manual with Locked transmission
I don't know if anyone else has had this problem, but would like to hear from you if you have. We were riding yesterday on a road close to home going about 55 MPH when the transmission locked on my 2014 RT SM6. We heard a noise, and then it was locked in sixth gear and we skidding the bike to a stop since the rear wheel was locked up. We have about 7500 miles on the bike and it is four months old. We believe it is something in the transmission. Has anyone else experienced this issue? Thanks,
Terry
Wow, I am glad you are both ok. I haven't heard of your problem prior and have not had any tranny issues on my 14 RT SE6; only have 2,500 miles on it.
Your clutch cable must have broken off or something else.
2012 Spyder RT SE5 Brake pedal mod
Could be anything in the drive train from motor, tranny, to rear wheel (and everything in between) if it's totally locked up.
Check the easy stuff with the belt starting at the rear wheel....
I have 2600 Mi on my 14 RT. Not a glitch anywhere
Not being funny, but make sure nothing got kicked up in the rear wheel. Haven't seen this on the Spyder but have seen two wheelers get something wrapped in the rear wheel and lock up. Just a thought.
USAF '69-'89 E7
Thailand/Vietnam 1972
Member: Royal Order of Rat Bastards
Only ever seen this on a auto rs with more than 200,000 k on it .it broke the teeth off the crank for the front cam drive and when the cam stopped the piston said hallow to the valves and engine locked up.but on a new bike very unlikely and I doubt if they will tell you the real reason why but would be good to here what they have to say anyway please keep us informed.
that doesn't sound good. I've got 14,500 on my 2014 SM6 and no problems at all shifting.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
