Front end noise I can't figure out
2012 RTS SM5
Noise coming from the front left side, usually when the wheel is turned and just starting to move through to second gear.
Like a high pitched metal chirping sound. Reminds me of a brake pad wear indicator on a automobile.
Never happens in a straight line.
Don't hear it at speeds over 50 KMH or about 25 mph.
Doesn't make sound when revving at a stand still.
Gets hearing in pitch until it almost sound like a screech and then goes away.
Any have this happen to them? Any thoughts?
Thanks in advance.
Little checking..!!
if you can lift the front end and spin the wheels to see if you can hear it. Check the front bearings, hold tire opposite sides and move forward and back then left to right. Check brake pads. Pull the wheels and inspect..good starting point..
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
After doing the checks above, make sure you are not really hearing a belt noise. When it happened to me, I put out a similar post about a rotational noise coming from the front wheel at certain speeds. When I focused more on the noise, I found out the noise was really emanating from the drive belt. I cleaned a tar glob with a pebble embedded in it from the driven sprocket, adjusted the belt tension and the noise is gone. ...Don
Similar sound on mine
I've got a similar thing on the right front (I think, but too many concerts in the '70's to tell for sure ). I posted a thread about it a while back, but got no definitive responses, accept have the dealer check...
It kinda sounds like someone burning rubber (squealing their tires) in the distance. That is to say, it's not really loud and mine is from start to 25mph, not necessarily just on turns . I may just not hear it when at speed because of wind noise....
I haven't taken the opportunity to have the dealer check it out, but it's been there a long time....
'12 RTL
~'12 RT Limited, Pearl White~
BajaRon Anti-sway Bar
Squared Away Laser Alignment
Custom Dynamics HMT Brake Light, Front Fender Tips & Kit, Front Mud Flap LEDs, Amber & Red Brightsides, Tri-color Magicflex Channelz
Lidlox Grip Tip Helmet Locks
TricLED Mirror Signals, RGB Multi-color Halo Underground Effects Kit, LED Headlights
Palmer Signs Custom "Captain America" frunk graphics
Twisted Chrome Pinstripes
Overland Australian Sheepskin Seat Cover
It can be many things to include the front bearings on the motor. The are located on the front left side.
Do not know anything about what your ride is or miles and etc... but be sure to include an inspection of those bearings -- just to be sure. There are reports of a few engines having problems there.
SL #7026
VBA #652
HOG #3935417
2011 Viper-Red Spyder RT SE5 & Trailer
2017 HD Ultra Limited
Former Rides: 2014 HD Ultra Limited; '04 Kawa Nomad; '09 HD Ultra-Classic; and many Hondas through the years.
Spyder Newbies Do's & Do Not's: http://www.spyderlovers.com/forums/s...-Spyder-owners
I think it is brake pads noise i hear on mine at slow speeds
What did I say?
I said right, but I mis-spoke.... it's on the left side. I'll try the suggestions above as well.....
Thanks y'all~
