Hot oil smell
I've been on here a few weeks and getting as much information on my future purchase but haven't seen this yet.
I purchased a new 2014 RTS yesterday with 0 miles and on my 2 hour ride home I kept getting a real strong burnt oil smell, like when you spill oil on a hot engine. I even stopped to make sure the dipstick was secured. After I got home I let it set a few hours and then rode it in the evening and the smell was still there. There isn't any oil on the garage floor. The dipstick oil isn't dark.
I have broke in a lot of new vehicles and they all have their own smells. Is this normal for the 2014?
Thank You
Don't know..!!
there were some problems with the case screws leaking but should have been fixed. This could blow back to the cta and or pipes and burn off. I would check to see if this fix was done. You can call the dealer and ask them to check by vin#...only other would be oil in the air box leaking out or water pump but not likely..you should not have a lingering smell any set up fluids would be gone after a few miles of ryding...
2012 RS sm5
We had a similar hot oil smell on our 2014 RT-S. It went away after a thousand miles or so.
That is how my wife's spyder was smelling 4 days ago, oil was coming from the seal behind the drive shaft pulley, seal broke and it was slinging oil allover the engine, check it out and make sure that is not it, i ruined my engine
SMELL
After letting it set overnight there was a puddle of oil on the floor. I took body panels off to see if I could see where it is coming from. All I could find was oil all under the engine and on the bottom covers. I could not see where it is coming from. The oil level was below the add mark.
I'll contact the dealer Monday to get it looked at.
Update on oil leak
Just a follow up on my oil leak. I trailered it for the two hour trip to the dealer. Found it to be a set screw that was loose on the motor. Apparently there had been a bulletin about this awhile back. My VIN did not show as having this problem.The set screw was loose and didn't have any lock tight on it. The dealer replaced it with the new one and put lock tight on it.
Thanks to those that responded.
Thanks for posting. This was a problem early on and was supposed to be fixed at the factory. Units that had already left the factory were supposed to be fixed by dealers prior to delivery via a repair bulletin. Glad you got it all solved and that you are back on the road.
Seriously both BRP and their dealers need to get their act together...are you listening Steve? This should have never happened and does not give us faith that BRP is delivering safe reliable vehicles. Oil can catch fire is that what it will take for them to make SURE this never happens again?
2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
My RTS was built in May 2014 and the VIN didn't show that it needed this repair. There is a problem in the system somewhere
2016 RTS Special Triple Black, BRP Freedom Trailer, Spyder Pops Rear Lighting Kit, Spyder Pops Full view Turn Signals, Trunk Light, Rivco Highway Pegs. Doc's Spring Tensioners, Trunk Organizer, Magic Mirrors, Foam Grips, back to Stock Windsheild, Lamonsters cat delete, Bajaron sway bar, More Farkles to come !!
