Center console switch blank question
Hi all,
I am toying with the idea of installing additional head lights on my '14 RT.
I was thinking of using the switch blank in the center console to locate the switch.
The questions: Not knowing what is behind the blank, can the switch be locate there ? And if so, is there a trick to taking that center blank off?
Ron
blank
Originally Posted by zbunker
Hi all,
Ron
That is For 7pin connector For communications system Rider n psgr and CB function.
Freebob...
Zbunker,
I am getting ready to do the same thing to control the underlighting on my '14 RT-S. I have popped out the center plug and there is plenty of room for a switch. I have ordered a waterproof marine switch that look identical to the other switches. Big issue will be the need to cut the switch console panel to make a rectangular opening instead of the existing round one. Would love to be able to pull the console panel to do the work but haven't been able to figure out how it is attached at the front by the glove box. The center button came out with a little work and some small screwdrivers like Bob mentioned.
CJ JAX
If the switch panel is anything like the 2012 RT there are those plastic push in things on both sides and one that is....yes, under the middle blank hole to the rear. It took me a while to get it out with a small screwdriver and I could not figure a way to get it back in being under the panel and all so it was left off. I had a heck of a time getting the plugs back on the switches (not much slack in the wires). I had to use WD40 and a screwdriver from underneath. Good luck!
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
I believe that they're supposed to make short work of these sort of jobs...
Hi all,
Ron
You might want to take a look at a thread that was put up today entitled "Stopped By A Deputy Sheriff. Is has to do with too many headlights.
Center Console Switch
Originally Posted by zuni
Zbunker,
CJ JAX
Thanks, As far as the switch type, what I had in mind was to order a switch from the dealer that is identical to the fog light switch. It would show a light symbol, and if everything goes like written in the brochures should fit right in. I'm still not sure where to locate the relay.
Ron
The blank pops right up. However, instead of a rectangular hole; instead, there is a round hole that is the exact same size as the round hole behind the cover below the left passenger handle. I too wanted to have a rectangular switch to match the other switches, so using a Dremel, I carefully shaped the hole to fit the rectangular switch. I used my switch to control my heated seats
So with some much needed guidance from Doc Riverside I was able to dismantle enough to remove the switch panel. The black push pins used in various locations are great for ease of dis-assembly and reassembly EXCEPT for the one securing the front of the switch console. That one pin is what forces all the necessary parts removal. Used a simple waterproof marine switch with a green led (to match the lighting it is controlling) which matches the other switches for $6. That entire panel could have been designed to snap in like the speaker grills making life a lot easier for negligible cost.
CJ JAX
Freebob...
Well, that explains something I've always wondered about the RT. I have never before seen a touring type bike that did not have a DIN connector for a wired headset. But then the RT does not have a built-in intercom either, so I guess that's why it's optional.
