Results 1 to 10 of 10
    May 2013
    Avon, IN
    Default Frunk switch problems
    After about a year, my frunk switch is Again not working. I have to manually open it with the key.
    Wondering if anyone has had similar problems with the switch?
    Wondering if anyone has easy'ish fix - not looking forward to taking it back to dealer to have it fixed. Yes, it's probably under warranty, but I don't really like my 'nearest' dealer that much anymore.
    2013 RTS
    Very Active Member Larry rt's Avatar
    Jul 2013
    Vestaburg Michigan
    I had same issue , stopped at BRP's trailer at Spyderfest , the told to take it to dealer to replace switch (warranty ). He stated that there is a spring in the switch that gets bent . If you don't hear the switch click then, you will need to replace. If the switch clicks, then it is an alignment issue.
    Very Active Member Pennyrick's Avatar
    Feb 2011
    Loganville, ga
    Quote Originally Posted by Rattigan_Roger View Post
    You can test if it is the Frunk microswitch by holding the lever arm down and pressing the frunk release switch to see if the actuator works.
    It’s easy to bend the switch arm.
    Or, you could pretend it's a '14.
    Penny and Rick have owned many motorcycles starting in 1974 with Honda’s, then to Suzukis, Gold Wings and ultimately Spyders.
    ‘74 Honda 360T (pair); ‘78 Suzuki GS 1000 (pair); ‘’82 Honda Aspencade; ‘84 Honda 400; ‘87 Yamaha 1100; ‘99 Honda Valkyrie; ‘01 Suzuki Burgman(triked); ‘02 Honda GL 1800(triked); ‘10 Spyder RTSE; ‘11 Spyder RTSM; ‘12 Spyder RTSL (pair); ‘20 Spyder RTL (current)
    Feb 2014
    Utica, Michigan
    Quote Originally Posted by Double Trouble View Post
    Low blow...
    Very Active Member Wiredux's Avatar
    Aug 2012
    Jacksonville, NC
    My 14 has a switch.
    Nov 2013
    Central Texas
    Quote Originally Posted by jpschulte View Post
    2013 RTS
    Yeah, mine is out again for the second time. It was replaced the first time under warranty. The switch clicks when pressed manually, but doesn't open the latch when pressed at the same time as the switch on the handlebar, and I can hear it click when I slowly close the frunk lid, so no alignment problem. I seem to recall an earlier thread about this, and I think that there is a relay between the handlebar switch & the frunk switch. This could be the problem that you (and me) are having. It's going in next week for service & hope to get it straightened out. One other thought. Is the key hard to turn to open the frunk? It so, check the sealing gasket on the frunk. Mine was ridiculously misaligned, and once I fixed that, the key turns much easier. Good luck, and let us know the outcome.
    If that little microswitch arm gets bent...
    ...Just unbend it!
    Invalid Emails
    Mar 2011
    Hudsonville, MI
    Is it the same switch that activates the light in the frunk?
    Active Member Gundam's Avatar
    Singapore
    Mine also failed after 6 months or so, 2013 RTL.... called the dealer and says to bring it down, but can't find the time to do so, very busy with work.... got a little bit of time some days back and did some DIY.... actuator checked ok, micro switch checked ok, so just simply bypass the original handlebar switch with a spare one (see my other posts).... works well until I can find time to have the original switch dismantled and repaired or changed.... funny thing is, I have checked the voltage from the original switch when it is activated, it shows 12+ Volts... but the actuator does not energise... I suspect the switch contacts are not fully closed, preventing the flow of higher current that is needed to energise the actuator...
    Singapore
    Quote Originally Posted by SPYD1 View Post
    Yes, it is...
Tags for this Thread
