Results 1 to 6 of 6
    Sep 2011
    Westerville, Ohio
    Default Flickering Lights and Gauges
    I have a 2010 RT SE5 that was running fine. Due to the weather haven't been able to ride for about 5 days. I finally was going to get to ride and when I put the key in the ignition, the display started flashing and the gauges were jumping around. Thought it might be a weak battery so hooked up the tender to it and when it showed a green light, tried it again with the same results.
    Anyone have any ideas on what the problem/fix is?
    western Colorado
    Quote Originally Posted by Buckeye Bob View Post
    Need to try a regular Battery charger. If the battery is low the tender won't do much.
    Jun 2010
    Las Vegas
    Were you able to start it?
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Default Have to agree..!!
    Roger
    a loose connection...check battery terminals and ground connections. Next would be the battery..could be holding a surface charge only. Don't know how old it is...
    ​2012 RS sm5
    Sep 2011
    Westerville, Ohio
    I greatly appreciate everyone's thoughts and inputs but I just haven't had the time to check for loose connections. Thanks again.
    Invalid Emails
    Dec 2013
    United Kingdom, North Wales
    Default Just for thought
    I had this problem, but I also had the LED light flickering when I switched off. Found out after much deliberation that the problem was on the battery connections either side of the seat and also the brake lights switch was faulty, Good luck and ride safe!
