RT-S PE#0032
NO CLUTCH
Go ready to head out this morning, but I have zero clutch. loose as a goose. Is it a fuse?
Any help that will point in the right direction would be greatly appreciated. (2010 RT-S)
Spyder Bytes: Kury ISO Grips, GL1500 Windshield Vent w/ accent, Heel-Toe Shifter(inspectorgadget), HMT Brake Light, 12v outlet in frunk, GPS-Phone mount w/ case( techmounts.com), seat seal, Right Side Grill Covers( customdynamics.com), Fan Can10(I SCIrides.com), CAT Shields( SpyderPops.com), Elka Shocks, PressurePro TPMS, Cobra CB....and of course Cup Holders( mycupholders.com)
Do you have fluid in the reservoir?
I seem to recall some issues with the fluids eating an o-ring in the system; causing everything to need some pretty quick cleaning and adjustments...
Take a look for posts like this from Nancy's Toy...
Se5 or Sm5..??
not a fuse usually oil related but your not having any clutch seems strange. What exactly is happening. It may be the shift lever is off if it seems to shift but not go anywhere. Do you have any fault codes..?? Was it fine the last ryde and when was that..??
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
clutch
I to have a 2010 RT-S which lost my clutch. The bike has been in the shop for two weeks now and no fix. New clutch kit, new master cylinder still no go Dealer says BRP not coming up with any answers. Now mechanic is on vacation
RT-S PE#0032
it was fine last ryde.... the clutch is just not there (no resistance). I managed to get into neutral, but if shift gears and it bogs down
http://www.spyderlovers.com/forums/s...ghlight=Clutch
There's about 7 pages of "Clutch", in thread titles...
Here's one that might apply to your situation.
Good Luck!
SAME PROBLEM
I JUST HAD THE SAME PROBLEM I WAS TOLD I HAD TO REPLACE THE CLUTCH ITS IN THE SHOP NOW IT SHOULD BE OUT SOON FOLLOW UP WHEN ITS FINSIH
BUT MY PROBLEM WAS MY BIKE WAS BOGGED DOWN ALSO I COULDNT GO OVER 25 AND COULDNT MAKE IT UP A HILL OF ANY INCLINE
RT-S PE#0032
That was it, resevior was completely empty
Top it up bleed it out should be good. Look to see what's leaking annual clutch hydraulic fluid changes will extend life of master/slave
Sent from my HTCONE using Tapatalk
2012 RT A&C bought new 42312 sold July 2018 56k miles currently driving a 2014 RTSE6 LTD bought October 2018 w 6800 miles nicely farkled
Little checking..!!
if the resevoir was that low you need to find out why..why you got no warning..and fix the leak... You don't want this happening on the road...
2012 RS sm5
Leaking hydraulic shaft seals or worn clutch plates will cause low fluid level.
USAF '69-'89 E7
Thailand/Vietnam 1972
Member: Royal Order of Rat Bastards
