Great Ride!
Hi All. Just have to add my two cents to the positive accolades shared about the 2014 Spyders. Put about 100 miles on my new 2014 RT limited this week and the difference between this machine and the 2012 I traded is amazing. Loved the 2012, but this machine is a quantum leap forward...in my humble opinion. Tranny is really smooth as is the ride in general. Had to unlearn the "keeping it above 4000 rpms". Using the shift points shared by Lamont in another post, can't even feel it shift. The low end torque...what can you say...wow!
Have a question about the ignition though.I depress the key to release the trunk and the latch allows the trunk to open but doesn't spring back to allow the trunk lid to lock without some serious persuasion. Has anyone encountered this and what are your suggestions? Thanks for the heads up.
Continue to be a very happy and excited Spyder rider.
Old - 2012 RTS
New - 2014 RT Limited. Spyderpops Bumpskid. Kott Grills, Bajaron Swaybar and Links, Polaris Shock Stiffeners, Custom Dynamics Brightsides Red and Yellow Fender Lights w/Turn Signal Module, Autozone Mirror LEDs, Custom Dynamics Rear Red Brightsides and HMT Brakelight with Strobe Module, Smoothspyder, Lidlox Handlebar Helmet Locks, Glo ryder 360's for Three Wheels, Pete's Graphic Kit, Mini Trailer USA Shadow.
And Growing!
Adjustment..!!
does seem that it is an adjustment issue or cable routing. Maybe a bit of lube would help....
2012 RS sm5
I agree the 14 RT's are fantastic. I am amazed every time I ride it. Good luck with your latch and let us know what you discover.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
Old - 2012 RTS
And Growing!
I have the same problem. i discovered it while I was still at Spyderfest & took it to the Pit Bull service guys. They made sure the frunk lid was aligned right. But they said it was how I operated the switch with the key! I still have to manipulate the switch to make sure it's set right to latch the frunk lid. I don't think it's right, but I deal with it. I may have the BRP or dealer guys look at it at BRP-OE.
Switch?
It's certainly possible that it's the switch mechanism.....However, I have had two Spyder RT's and both worked just fine after the frunk lid was aligned and the actual latch was located properly (up or down) to have the frunk lid close to the desired level. Could also be cables from switch to latch. How's the seat latch operating at your switch? Is that OK or difficult like the frunk lid?
I know it can be frustrating....I would have the dealer look at it -- I don't buy that it's your technique at the switch...something's wrong! IMHO.
Good luck!
Happy and safe rydin'
2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
I have not had that problems with my 2014 but I do know someone else who is having the same problem. The interesting thing is that she had to wait for delivery of her Spyder due to the ignition/key service bulletin. Do any of you know if your Spyders were manufactured after the key issue came up?
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Old - 2012 RTS
And Growing!
