Passenger foot rests
Any good idea on how to loosen the bolts for the passenger foot rests ?
I tried using the tool in the tool kit and a allen wrench on a socket, just managd to burr the bolt heads up. Tryed putting wd-40, but no help.
I know about the jam nuts on back and they were removed already.
First time in years, my wife has wanted to ride with me, but the foot rests are way to low.
thanks for any ideas.
Oldmanzues
Floorboards or footrests? My floorboards didn't have jam nuts (that I noticed anyway) and I used the tool from the toolkit and a screw driver blade
I believe all, or at least mine used a typical 3/8" drive
Oldmanzues
socket. I am not sure of the head size, but I think it is 10mm or 13mm.
Lets ride!!!!
The jam nuts are all the way at the end under the Spyder. I guess to keep it from falling off if you can get the bolt out that far.
Whater the right name is, they are passenger foot rests on a 2010 RT. The fastener you can see from the outside goes in a block on the frame
What is your ride and are they stock floorboards, or pegs? For 2013 BRP changed the floorboard attachment on the RT from an Allen head bolt to a Hex head bolt on the RT. Definitely metric, not SAE. Bolt head on the floorboard side, nut on the backside. When loosened, you can move the floorboard up or down as you wish.
Well now..!!
this would be a good time to beg borrow or steal a hammer operated impact driver. Best friend to the byke owners...air impact will work or electric as well. That and some penetrating oil and your set....
2012 RS sm5
2010 stock foot "boards" This problem is probably why they changed it. Nice feature, if you can get it to work.
Thanks for the help, everybody
Oldmanzues
I found that a regular socket was too thick to fit into the counter sunk hole the bolt is in. I had to use the socket tool in the Spyder tool kit along with the screwdriver shaft in the tool kit. The bolts were a bit tight but I was able to get them loose. Don't take them all the way out! Just enough to slide the foot rest up. Hope this helps.
