SENA SM10
I had SENA SM10 installed at the dealer on a 2014 RT. When I went to pair the helmets the pairing lights would not come on but the red charging light was on. I thought that since it was connected to the power source of the machine that it would always have power.
My question is do I have to shut this off when the RT is not in use?
With the Gold Wing I had J&M and this was not an issue and it was also hooked to the power source.
Thanks All
The simple answer is yes. If it is dead, you can remove it from the clip and charge it with the headset charger for about 15 to 20 minutes and then while you ride it will complete the charge. I do not know where yours is located, but I moved mine to the glove box for easier access.
It does not charge when bike is turned off. I learned that the hard way
220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
I was afraid of that
It was installed in the front trunk under the liner cover and they must have it glued down because it sure is down tight and could be a real pain to remove
It sure is a pain to get to where they normally put it. If I had it to do over again, I'd have had them install it in the rear trunk. Probably very expensive to have it relocated now, but I will say it's not a problem if I'm on a trip. Turn it on when I take out the backrest and put in the front bag, turn it off when I take the bag out and put the backrest in. It's just in a bad location when I'm just running around with nothing in the front compartment.
It would just be a lot better if it turned off and on with the key.
I installed mine in the rear trunk. Yes you need to shut it off after a ride. It does not charge while bike is off. However, as stated a few minutes on charge and it will work and continue to charge as you ride.
2014 RT Limited Black Currant, BaJaRon Anti-Sway Bar and Links, Show Chrome Luggage Rack, Rivco Trunk Mounted Double Flag Holder. More to Come.
08 Honda Aero - wife's
14 Kymco - wife's (Hmmmmm...i'm losing bikes)
Another pain you will find when it's in the frunk is sometimes it will not automatically bind to the headsets.
To help, turn on your headsets first then turn on the SM10. If you do it the other way the SM10 will time out and you have to push the button on the SM10 to rebind.
Bob
2011 RT-S SM5 - Black
I relocated mine to the trunk and powered it off the accessory outlet. It now stays charged all the time and pairs as soon as I turn on my headset. The module works well, its the custom BRP harness and suggested mounting location that suggests the person designing the kit did not use it.
