New member with a question
Last week I bought the 2014 RT, what a nice ride when I'm by myself. However when my wife rides with me there seems to more sway, less cornering control and just not as smooth a ride. I checked the rear shock pressure and it's at 70 lbs. How do I stabilize the ride with a passenger to feel confident that I'm in control?
I have the rear shock psi at 30-35 and find it it's a smooth stable ride.I would also check tire pressure front and rear.
Make sure she knows how to rida as a passenger.
If she's not leaning with you, and just hanging on, that'll throw you off. If you're both new to the Spyder, you need to "learn" how to ride.
When you do, you'll have a blast!
Passenger must help by leaning into corners a little. You can also upgrade with a laser alignment and a Bajaron sway bar.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
Obviously, the best solution is to get another Spyder for her own!!
Agree..!!
with the above. Leaning, bars, tire pressure but might check the seat sensor to make sure it is recognizing the passenger.
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Also adjust the shocks on the dash. Increase them all the way.
Dan
2012 Viper Red Rt
upgrades:
Baja Ron's Anti-Sway
Diamond-R Arm Rests
Gloriders
High mount brake light
chrome front fender garnish
Bad Boy Horn
Chrome Deflector Rack
Chrome Scuff Nose Accent
Handlebar Grip Fringe
Gremlin Bells
