Oil Type
Wondering what kind of oil can be used in my 2012 RT. Can any synthetic oil be used? The kits are quite expensive and I don't need everything in them each time.
Expensive? Really? $57 for the sm5 and $66 for the se5....
SpyderLovers Sponsor
I am curious as to what comes in the BRP kit that you don't need?
Here's the thing..!!
if your doing it right...you need everything that comes in the kit. If your short cutting all you save with cheap brands and double using filters and o rings etc. will cost you dearly later on. You can get what you need from BajaRon, and any oil meeting the spec's will work. Do make sure of that regardless of what oil you use..
2012 RS sm5
Interesting this question came up today. I just went through it myself. The BRP kit comes with everything including the oil. I didn't want the kit as I use amsoil. What I found to be a rip off is they charged me for the filters, the "O" rings and the gaskets. Every other filter I buy, if the filter is not a spin on type and requires an "o" ring, it comes with the filter.
Oil Type
Our local dealer charges $80.00 for the everything. I thought I could get a synthetic oil and buy the filters seperate.
Yes, you can do that too.
2010 RTS-SE, Orbital Blue
Ron;
Have you found a supplier for the new style trans. filter, yet?
I use Amsoil 10W-40 motorcycle oil. You can get the Amsoil motorcycle oil, engine filter, and a O-Ring & washer kit from BajaRon. The new trans filter from your dealer. That's IMHO.
Mike
