Laser Align
How many of you have had the laser alignment and have not noticed a difference in operation?
USAF '69-'89 E7
Thailand/Vietnam 1972
I am pretty sure this is an instance where someone could say "I CAN speak for everyone when I say that EVERYONE has noticed a difference" If you have yours done and it needs it (which a great percentage of them do) then you will definitely notice a difference. Add the BajaRon Sway Bar if you haven't already and it will be a completely different bike.
I had mine done , 2 in. Off to right. Did not notice that much of a difference , BUT , prior to this had bad wear on outside of front tires! After alignment and 5000+ miles no uneven ware ! I am sure the alignment resolved tire ware! Also did sway bars, a little stiffer in corners now , less sway.
I think prior to 2013 models see more of a difference , the 13's because of changes are stiffer and track better . That is my opinion .
Larry is correct...2 ways to know the change...
# 1 if you ride alot your body will tell you it is better( or maybe your arms will tell you !!!)
#2 is tire wear...if you notice odd tire wear your Spyder is not aligned correctly. After the last Spyder event I have done over 300...and only 5 have been perfect. The laser system debued at the owners event at Maggie Valley 2013, so this laser technology custom designed for the Spyder has only been around for less than a year.
No matter what.. get yours CHECKED....you might be one of the perfect ones. But you won't know until you have had it checked.
I felt a slight differance. It was not a night and day type, but I the steering felt tighter. The teck said the right side was out 1/2" and the tires were showing signs of uneaven wear.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
Banged Up Member
It, the laser alignment, is a "must". So much of a "must" that I've suggested to my dealer, Seminole Power Sports in Sanford, Florida, to include it in the "prep fee" when a new one is sold.
Chris
On my RT I wasn't too sure until the high winds in the Mojave Desert kicked up.
It probably rides better just like a clean car drives better
2017 Chevrolet Camaro SS convertible. 2017 GMC Sierra cc diesel. 2017 Arctic cat RR 137 ES
I didn't notice and difference after the laser alignment. I got my alignment done at Honda of Winston Salem. The tech found one wheel 1/8 inch toe out. The tech said it was the second best one he'd seen. When I got my alignment done, the tech said he had done about 25 laser alignments.
The best one was in perfect alignment.
2012 RT LTD Lava Bronze, Ultimate seat, backrests and fuel door. Two Brothers Titanamium. Laser Alignment, Seals Floorboards. BajaRon Sway Bar and links, Spyderpops blockoff, Grilles, Missing Belt Guard, Bumpskid, Gold Wing Windshield Vent, Kewlmetal Helmet Locks, Rumbling Pride Flag Holders, Cup holders, Signal LED's on mirrors, Baker Built belt stabilizer, gremlin bell, Bad Boy air horn, TricLed 1st, 2nd, 3rd and 4th taillights and fender LED strips. RT-622 trailer, ........More to come.
Pragmatic Member
Is there a way to know for sure that my Spyder NEEDS to be aligned before I drop $150 on a laser alignment? I'm a Charter Member of the "If It Ain't Broke, Don't Fix it" club. I've only had mine three weeks and 1,600 miles, and it feels fine to me. Especially after installing the BajaRon Sway Bar.
Thanks
Pam
- 2015 RT-S Special Series / Red & Black
- Baja Ron Sway Bar
- Utopia Backrest
- F4 Customs tall and wide vented windshield
- Stebel Super Loud Air Horn
- Baker Built Air Wings
- LaMonster Highway Pegs
- SpyderPops Exhaust Block Off Plate
- SpyderPops KOTT Grill
- SpyderPops Belt Guard
- Cat Bypass
- Laser Alignment by Squared Away
- TricLED Fender Lights
- General Altimax RT43 rear tire
- Dual flag holder
- Mud Flap
- A$$hole seeking missile system
it seems to me BRP could do a better job on alignment... why should just about every new spyder need alignment ?
osm
I had mine done early last summer. Both fronts just slightly out of alignment. This spring I noticed severe cupping mainly on the left front, slight cupping on the right front. I had another alignment done and the left front was out quite a bit and the left front tire was basically junk. So I also replaced the front tires also. Federal EVO's.
Long story short, dont think if you had it done one time you will never need it again. POT HOLES will wreak havoc on your alignment.
2016 Spyder F3 Limited Steel Black Metallic
Lamonster approved LED Headlights
Lamonsters LED Fog lights
BRP Driver & Passenger backrest
BRP Trailer Hitch
Shamrock Black & Polished
Signature light
Elka front shock's
Rolo Laser Alignment
Dual Power outlets
Garmin 590 GPS
Pam
In a short word, no. Unlike car manufacturers that turn them out by the hundreds of thousands and have their acts together, BRP has no such volume and does has a rep for turning out misaligned Spyders. The 1,600 miles you have on yours may give you an indication if your tires are wearing equally evenly but it's tough to tell. Would you prefer to spend $150 to know your Spyder is properly aligned or maybe spend it prematurely for new tires. JMO.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
Find a straight stretch of un-crowned road with no traffic, ride along the road at a speed just high enough to engage the cruise control, barely lift your hands from the grips and see if the bike drifts left or right. Not as scientific as getting it checked, but can let you know if you have a major problem. Again you need to keep your hands close enough to latch on in a hurry and I would only do it on roadway that I had rode along and checked for holes, etc first.
Clifford Fargason
2013 Spyder RTL
2007 Royal Star Venture
2010 RTS-SE, Orbital Blue
Thanks
Pam
I know a couple of vendors that use the ROLO laser alignment system, do not charge if the bike is not out of alignment.
Pragmatic Member
What exactly is the difference that you notice?
Pam
- Baja Ron Sway Bar
- Utopia Backrest
- Cat Bypass
- Dual flag holder
- Mud Flap
My 2010 had a lot of handling problems. RonBar. Badly worn tires. Three alignments in the shop prior to the introduction of laser alignment.
I bought my 2014, and had the laser alignment done within the first week of delivery.
I didn't have enough time to notice any difference.
Nevertheless, I consider it very good insurance.
IBA #47122
2020 RT Limited Asphalt Grey
Netzley's checked mine for free!
Thanks
Pam
I went to Netzley's in NY for a laser alignment and installation of a BajaRon swaybar. I watched them do the alignment on my 2015 RT and it was spot on. When it came time to pay the bill, he said he wasn't charging me for the alignment cause it hadn't needed any adjusting! I'm definitely going back there when it's time for new tires, even though its a bit of a trek for me.
p.s. The swaybar changeout definitely stiffened up the cornering. Don't know if that's due to the swaybar itself, the solid heim links, or both. But definitely worth it.
Scoot
2015 RT-S
BajaRon swaybar, Spyderpops BumpSkid, Battery Tender power connector, the "Missing Belt Guard", "Don't Eat The Mud" mud flap, JT's dash mount, RAM mounts for electronic stuff.
Pam
To me the RT felt effortless to ride.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
I gained a consistent gain in MPG, picked up 2 MPG. Mine wasn't terribly off but my steering sensor is what made a biggest difference. It was about 2-3 degrees off center. So it was causing a constant pull.
2010 RT Audio and Convience SE5, wider vented windshield, XM radio, digital voltmeter, K&N filter, LED turn signal strips, ISCI floorboards, Lamonster LED Headlights and Fogs, Two Bros Black series
Squared Away did mine at Spyderfest and I noticed the difference mainly on the ride home.
Shoulders and back ached on the way out as I had to constantly micro-correct the Spyder, especially on the highways. On the way home the bike didn't need anywhere near as much corrections and on straight and true roads (like much of US60 East of Springfield) the bike would track straight without wandering.
I'm a believer.
Trb-- (Roger)
2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
2022 White Pearl F3T
Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
Spyder States Visited
I had both my 2013 & 2014 RTL's done and neither needed adjustments. I was still charged.
2015 RTS Ltd Spyderpops bumpskid, Dual Isci Hand Brake ,Baker Wind Wings
2016 Polaris Slingshot SL
