Results 1 to 13 of 13
Thread: Parking brake
    Aug 2013
    Media, PA
    Default Parking brake
    Turned the on and got PARKING BRAKE on the screen. Turned the key off then back on again and all was good. Trouble coming?
    Aug 2013
    SF Bay Area
    HUH?
    While ignition is on you switch the parking brake on, see the red indicator in the speedo then turn the key off. When you turn it on the P brake should still be on.
    2021 F3 Ltd , Magna Red
    Aug 2013
    Media, PA
    Default PARKING BREAK
    That's understood, I set it whenever I park the bike.
    The problem is the words PARKING BREAK showed up on the screen. I haven't seen that before.
    Default Curious..!!
    does it only say parking brake or is it followed by failure..could it be a warning the brake is on that comes on if you put it in gear and try to move..?.. Check fluid levels anyway just in case...
    Clermont, Florida
    possible spurious event - only time will tell
    Jul 2013
    United States
    2012 rt parking beak problem. Parking break is locked in on position. Checked fuses and brake fluid. Any other suggestion?
    Jun 2013
    Fleetwood, PA
    Quote Originally Posted by PowerguyMike View Post
    You probably checked everything you can check. Now just remove the cable down at the brake caliper. This will release the parking and you should be able to drive it to the dealer. Unless BUDS puts you in LIMP mode.
    Apr 2013
    Atkins, Arkansas
    Similar issue this morning, pulled out of the garage, put on brake turned engine off to run back into house for a few. After restarting Spyder parking brake would not release with amber brake light flashing. Turned engine off (always count to ten) turned ignition back on warning still present (Code C004B not in Spyder Codes) STARTED ENGINE, PRESSED HARD ON THE BRAKE PEDAL PRESSED BRAKE RELEASE SWITCH AND EVERYTHING BACK TO NORMAL. Went on Poker Run his morning without any additional issues.
    Invalid Emails
    May 2013
    Butler County, Western PA
    My parking brake also stuck yesterday. I pressed the button to release. The light went out, but the brake stuck and it kept beeping at me when I would try to pull forward. It finally released. I was able to go. When I stopped to park, I got an orange screen that showed "Parking Brake Fault". I pulled the key and was off of the bike for 15-20 minutes. When I returned, all was well.
    Active Member Dgjason's Avatar
    Old River Winfree Texas
    Quote Originally Posted by 03hdjill View Post
    Which spyder had the problem. I also have a 2013 st l.
    Invalid Emails
    May 2013
    Quote Originally Posted by Dgjason View Post
    My ST Limited.
    Apr 2013
    Atkins, Arkansas
    Once again I had the same issue as back in August. Stopped by my Honda Dealer and we hooked it up to BUDS said error code is a brake sensing switch or low brake fluid. Brake fluid OK so we will go back to Honda House in the near future for a Troubleshoot session. Code C004B is what I have but it is not in the Spydercodes.
    Apr 2013
    Atkins, Arkansas
    Default My Problem solved
    Bottom line, check brake fluid level when bike is cold, added 36 ml this morning to rear chamber. After that could not reproduce error.
