Page 2 of 2 FirstFirst 12
Results 26 to 45 of 45
  1. #26
    No rain or wet water wash yet. Will be watching to see if there are any leakage issues with mine.
    Registered Users mtdoragary's Avatar
    Jul 2010
    KILLEN, AL
    Checked mine today. Wet inside. So far not impressed with dealer setup even though they DID hurry to get it to me. Trunks don't latch right. Trunk leaks. Front tires had 5psi. My Harleys were ALWAYS set up better than this. But it's still ten times better set up than my Excelsior Henderson!
    3:16
  3. #28
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    Quote Originally Posted by mtdoragary View Post
    Sounds pretty close to mine, except for the tire air pressure, which was set exactly right. I took mine back for warranty work on the ignition and complained about the frunk leak. They sort of fixed it, but still have not gotten the side case releases right. So, back to the dealer.
    2020 RTL SE6
  4. #29
    Very Active Member cognaccruiser's Avatar
    Dec 2013
    South Okanagan, BC, Canada
    Default Mine Too
    Last week when I washed my '14 RTS, I decided to check and there was water in the bottom of the frunk. Easy to blot up the water but haven't done anything about it yet. I'm wondering if it will do it while driving in the rain or if it was just because of it standing still with lots of water being sprayed on it with the hose. I know that either way it shouldn't happen. Latch seems to work well but perhaps it needs to be pulled tighter when closed. Will have to try the dielectric grease test.
    Gary
    States visited by Bike
  5. #30
    Invalid Emails
    Jul 2010
    1/2way tween STJames and Salem Mo
    Thumbs up solution to leak
    Mine leaks, its a 2010 and my solution was a LARGE plastic bag with NO holes. Put all into the bag close well.
  6. #31
    Danbury Connecticut
    I got caught in a pretty heavy downpour yesterday. No water in the front trunk.
    IBA #47122
    2020 RT Limited Asphalt Grey
  7. #32
    May 2014
    Bridgeton NJ
    I have a new 14 and discovered everything in the frunk gets soaked after rain or washing.
  8. #33
    Active Member iSpyder's Avatar
    Jun 2012
    Georgia
    Default Frunk Leak Identified
    -iSpyder
    2014 Spyder RTS - Cognac
    2012 Spyder RTS - Blue (17,700 miles)
    Current Mods:
    BRP Backrest
    ISCI Hand Brake w/ cup holder
    ISCI center screw RAM mount w/ universal holder
    ISCI driver and passenger floorboards
    FZ-1 fuse block
    Powerlet 12-volt socket installed in front speaker grill
    Stebel Nautilus Compact Horn
    Hopnel dash bags and saddle bag nets
  9. #34
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    Quote Originally Posted by sassoman View Post
    made me curious about water getting into the front trunk so I got into my front trunk and closed the lid and had my wife spray the front with a hose while i held a flashlight.No leaks on mine! Man ,you can store a lot of stuff in that front trunk.
    Good to see somebody had the sense to really get to the inside of the matter.
  10. #35
    Apr 2015
    higganum ct
    Cool hi abc
    hi my name is skip i'm from higganum ct what i have done is to use a heavy trash bag because of that very thing happening to us
  11. #36
    Very Active Member pitzerwm's Avatar
    Nov 2014
    TriCities, WA
    You people are so gullible or just not reading. You couldn't get a 2 year old in the trunk and if you did they couldn't move around to see anything.
    Trailer yes, front ftrunk NOT even.
    One of the hardest decisions you'll ever face in life is choosing whether to walk away or try harder.
  12. #37
    Active Member kywinger's Avatar
    Sep 2015
    Carrollton, KY
    My Frunck leaks while parked. The water is coming in through the joint where the two halves of the join, just below the fuse covers.
    Pit Bull stated it would take about four hours of labor to remove the frunk and separate the halves, seal them and remount the frunk. Pit Bull also stated there is a drain behind the frunk under the latch assembly which might be plugged.
    I will pull the frunk sometime and try to seal the joint, check the drain.
    2015 Red Pearl RT-S
    EXO2 heated Vest/Gloves
    BAJARONS sway bar
    TricLEDS side markers
    Xenon Depot LED Head & Fog Lights\
    Missing Belt Guard
    Bump Skid
    M2 Shocks front/rear
    Russel Day Long heated seat
  13. #38
    Very Active Member Buckeye Bleau's Avatar
    Aug 2015
    Canton, Ohio
    I seem to recall seeing someone that sells a "better seal" for the frunk, anyone help jolt my memory on who or where?
    Mine is separating a little in places and adhesive is letting loose.
    Joe
    U.S. Army Viet Nam Era Vet
    Utopia Deluxe driver backrest
    LED fender lighting
    Fast Flash LED brake light
    Spyder Pops LED/skid plate
  14. #39
    Dec 2013
    Quote Originally Posted by kywinger View Post
    That is exactly where mine was leaking as well as some others. The entire tub was replaced under warranty and has not leaked since. As good as I know Pitt Bull is as a dealer, not sure why they are not just getting a replacement tub for your frunk.
    Gary
  15. #40
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    This problem developed for me recently after over 1 year old and over 11,500 miles on my 15 RTL. I have washed this thing and ridden in the rain too many times to count and never had any water in the frunk. Now, two rainy days in a row, I've got standing water in the frunk. After reading the posts here, I pulled the liner and rain a hose into the drain hole at the latch. I had a steady stream of water pouring into the frunk from the upper mount hole of the Bluetooth dongle bracket. The hole that has the plastic barbed pushpin in it. Since I've already moved the dongle to the rear trunk, I removed the bracket entirely and plugged the hole. No more water!!
    2020 RT Limited , Marsala Red
  16. #41
    Sounding like a gasket. An easy fix.
    Active Member Charlottes Web's Avatar
    Northeast PA.
    My 2014 rt trunk leaked coming home from Spyderfest
    Christine
  18. #43
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    Quote Originally Posted by Buckeye Bleau View Post
    Joe
    SpyderPops sells a replacement. I bought one at SpyderFest because mine started to come apart.
  19. #44
    Dec 2014
    S.E. Michigan
    My frunk leaks, none of the other luggage on the Spyder leaks. The bags have leaked on every motorcycle I ever owned. Most of them I'd put a little hole in the bottom to let the water drain. Afraid to do this to the frunk, because I'm not sure what's under it.
    I'm going to put a new gasket on the frunk. and start putting vulnerable items stowed there in waterproof containers.
    ~Sandee~
    ~Sandee~
    2016 RT-L (Purchased used in February 2018)
    RT Dash Mount (from JT's Spyder Store)
    Kuryakin Trident Highway Pegs
    Hopnel Pouch
    Magic Mirrors
    Spyderpops Foam Handgrips
    Iron Butt #35273
    Girls on Spyders #2779
  20. #45
    Quote Originally Posted by sandeejs View Post
    ~Sandee~
    Considering the design of the hood and the edge of the Frunk I doubt that's where the leak is …… The most reported location of leaking is from the seal for the Battery access port ( large square thing on the back of the Frunk wall ) and or the covers for the fuses …… Mike
Tags for this Thread
