Best products for tar and bug removal
Any suggestions for good products for tar and bug removal?
Turtle Wax- Bug and Tar remover- green bottle- been using it for years. Once you use it they clean off real easy the next time.
The mixture of vinegar and rubbing alcohol with a drop of dish soap is what a good buddy of mine told me about that has used it for 20+ years. Works great and is cheap!
http://www.ehow.com/how_4499658_clea...r-alcohol.html
** Loving my 5th Can-Am Spyder since 2007! **
WD40 it cleans off everything, just remember to re wax the area you clean. people i know that by old bikes use it to clean up the bike and i can't believe how well it cleans it up
NO BIKE AT THIS TIME
i use a product called BugSlide. It is safe for paint and windshield. Works great in Texas, and soon i will be able to test it in FL against the lovebugs..
2012 RT Limited
SpiderWrap Graphics
KewlMetal DualKewl FenderZ Running Lights
TricLED Dual Running & Brake Lights
Seal Floorboards
Bajaron Anti-Sway Bar
Utopia Backrest
Diamond R Luggage Rack
SpyderPops Upper Blockoff
SpyderPops Catalytic Converter Shield
Karnak Karna Klean, it has natural orange oil in it, you can get it at any roofing supply company
that stocks Karnak products. We sell it at my work it a little on the high side $21.00 but it is
worth it, and it is safe, you can use it to clean just about any thing, if fact I worked into my house
and I had grease on the bottom of my shoes, yep right on the the carpet. I used the karnak klean
and it cleaned the grease up and did not hurt the carpet. It comes in a 1 liter bottle, it works great
on the body work of all my vehicles.
There's Bug-Strikes...
...And then; there's THIS!
Thanks for the suggestions. I have never had a bike that would get as dirty and covered in bugs and tar as my ST. Mark's blue RTS always looks great. My white ST L always looks like it needs a bath.
Choices choices..!!
white will show everything that hits it...lets face it, not many light colored bugs... I have use WD-40 since it came out and works great. Now the new specificly designed products should be good but I have too many cleaning products as it is.
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
a friend of mine also uses WD40 on his knees and shoulder for pain and stiffness
Mr.Clean magic erasers work excellent.
Do they even work on tar?
A bucket of HOT Water and some car wash soap ( can be found in Walmart) Blue liquid and some elbow grease This worked on my 12' spyder after I drove it home from Ohio/ Penne. Boarder 613 miles. Deanna777
Tarminator
2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
Invalid Emails
