Results 1 to 8 of 8
    Wisconsin
    Default 2010 RTS SE5 tach question
    Hello everyone.
    I picked up a 2010 rts last November and I've finally been able to get out on it.
    Anyway, the Spyder has been running great but........ The analog tach decided to stop being accurate.
    Reads about 1200 rpm low. Also, the outside Temperature read out is way off.
    Is this the bad instrument cluster problem I've read about?
    No codes in the computer. only 1500 miles on the bike.
    Aug 2013
    Quebec City, Quebec
    For the temp, all RT gauge read 2-3 degrees over. No problem for the RPM on mine.
    Very Active Member finless's Avatar
    May 2013
    Stanton, ca
    Quote Originally Posted by tigerdr View Post
    2-3? I wish mine did! It's like 5 over for me and most other 2010-11 RT's I have seen are about the same.
    The can-buss provides the RPM to the cluster. If the analog gauge is not reading then something is wrong with it. I would go get it replaced if you care.
    The Spyder is weird in that it has duplicate things for some things. e.g. RPM on a analog gauge and also the digital gauge. I do use my analog gauge for RPM but not for speed... The digital seems easier to read for speed.
    I have also unplugged my analog gas and temp gauges because those are just not as accurate as the digitals. I now have added a analog voltage gauge where the analog temp gauge was and used my "hole" for the analog gas gauge for a RAM ball mount system.
    My 2 cents.....
    Bob
    2011 RT-S SM5 - Black
    Wisconsin
    Quote Originally Posted by finless View Post
    My 2 cents.....
    Bob
    Thanks, so no big deal I guess. I might have to try to unplug the gas and temp gauges. Probably a how-to somewhere!
    Default Let's see..!!
    the temp guage reads the temperature of the air flow to the throttle body and usually differs from your outside temp. If your comparing the digital tach to the analog tach there may be a problem with the needle dragging. You can get in there but would not try unless really nessesary. Check with your dealer for warranty coverage....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Wisconsin
    My spyder fixed itself! For some reason the tach worked great today.........I'm not going to argue with it.
    My bike must have spent a lot of time sitting, lots of little issues.
    Very Active Member Dan_Ashley's Avatar
    May 2013
    Redlands, Ca
    Quote Originally Posted by x1050er View Post
    A self-healing motorcycle!
    Dan
    2012 Viper Red Rt
    upgrades:
    Baja Ron's Anti-Sway
    Diamond-R Arm Rests
    Gloriders
    High mount brake light
    chrome front fender garnish
    Bad Boy Horn
    Chrome Deflector Rack
    Chrome Scuff Nose Accent
    Handlebar Grip Fringe
    Gremlin Bells
    RT-S PE#0031 MarkLawson's Avatar
    Jun 2009
    Snellville, GA USA
    I've had my analog tach read wrong RPMs before (digital read right) on my 2010 RT-SM5. BRP replaced the tach.
    Mark & Mary Lou Lawson
    Snellville, GA USA
    '10 RT-S PE #0031
    '10 RT-622 Trailer
    '08 Yellow SM5 #2332
    '01 Black GL1800A Goldwing #0930
    "Remember in the darkness what you have learned in the light." - Joe Bayly
