I'm in the process of install a fuse box so I can hook up an additional 12 volt outlet and alarm. I need to splice into a "switched" power...such as running lights. I also need to find the left and right turn signals for the alarm.
Can anyone point me towards those specific colored wires on the 14'? I have the covers off the entire left side and can see the main wiring harness and connectors.
2014 RTS White
Spy alarm, 12v DC outlet on dash, Custom Embroidered Seat with Gel insert, Anti-Scuff pads for passenger
It would be proper to contact Lamont (site owner) prior to advertising on this site.
Cruzr Joe
I mounted my alarm under the seat. I got the power from the trunk power outlet. I used the trailer harness connector under the old battery panel under the seat, to connect the alarm to the lights. Easy hookup. I don't have the wire colors handy but can get them tomorrow.
Thank you, I'll take a look later today. So the orange is the "switched" keyed power.
The ULTIMATE answer is to download the 2014 shop manual and pull up the wiring schematic. The entire manual is in PDF / CD from Midwest Manuals for about $29. Then you'll have everything at your fingertips.
I'm about to tear into several electrical mods and had your question and many others. The $$ is small compared to the instant answers now and later.
____________________________ Phil - Tyler Texas 2010 RT-Premiere Edition (Named DARTH) | Timeless Black | All My Mods--- ARE HERE | Phil. 4:4
I did just that Phil last night and confirmed those wires that Doc was nice enough to send me. I was just getting impatient and wanted to get it started. I'm with you...a full manual is a must!
Now I'm just looking for a "switched/keyed" power wire I can tap into that's closer to the left front so I can hook up my fuse box. The beauty of these types of forums is that they are filled with people who don't mind sharing some helpful hints and tricks...saves a lot of time finding things...which equals more riding time!
2014 RTS White
Finally all done! Thank you for all the help. Gotta love this forum. A couple of members actually pm'd me a offered me to call with questions. I hope I can help someone in the future...I've found out that the 14's are wired a little differently, obviously partly because of the battery placement change.
Fuse box, spy alarm and front dc outlet installed and in working order
I'm getting ready to install my FZ-1 fusebox on my 2014. Curious about where you ended up tapping into switched power for yours?
Thanks in advance for sharing!
-iSpyder
2014 Spyder RTS - Cognac
2012 Spyder RTS - Blue (17,700 miles)
Current Mods: BRP Backrest
ISCI Hand Brake w/ cup holder
ISCI center screw RAM mount w/ universal holder
ISCI driver and passenger floorboards
FZ-1 fuse block
Powerlet 12-volt socket installed in front speaker grill
I ended up buying the online shop manual and tapped into the frunk power. I can't recall the color of the wire. It was fairly easy since it was located on the front left side while sitting on the bike
2014 RTS White
Thank you! I will try to find it. I have the shop manual for the 2014 as well. and the wire colors are Black (18 gauge) and Violet (Main)/Yellow (Tracer) the other way. Do you happen to remember if you tapped violet for the switched power? From what I see on the diagram that appears to be correct but just wanting to be extra careful. On the diagram it appears Black goes toward battery and violet heads off the other way.
-iSpyder
FZ-1 fuse block
I'm sorry I haven't been much help...I haven't been visiting the site too much, I'm getting ready for heating season in the NE and cutting cord wood. For a switched power, I tied into the LED Frunk light. I'm not sure of the color right now and tried to look back in my emails to other members but couldnt find it. I remember finding it on the wiring diagram and just confirming the colors and checking with a meter. It's on the left side near the top of the frunk...easy access and worked well for the fuse block.
2014 RTS White
On the contrary, you were helpful. I decided that I will tap into the black wire that will connect to my third party 12v power outlet that I will be installing in the frunk. I realize that it can be changed from switched to constant in the Spyder fuse box but I will be leaving it as switched. I just need to be sure and pass that information on to any future owners IF I sell it...
Thanks again!
-iSpyder
FZ-1 fuse block
