License plate light lens fell off again.
License plate light lens fell off again. Anyone have a good screw setup to hold them on? This is the 3rd one that fell off. I might put two small cables on the sides so it can't fall off, but that would look like hell.
Mike
No plate light
I did away with it all together along with the ugly reversing light and all the brackets that were associated with them.
Replaced it with two black led tag bolts from Custom Dynamics.
Neat as.
Alan:
2013 Spyder ST Limited
TBR Black Series Slip-On Exhaust with M-5 Carbon Canister and P1X power tip and black bolt kit
Fox Podium shocks
BRP Carbon black sports rack & backrest
Custom Dynamics LED converted taillights & black tag bolts
WrapMySpyder carbon dash kit & GT stripes & graphics
Bestem USA carbon side fairings, belt guards & under tail
Procoat NZ powder coated wheels
Hydrographics NZ carbon dipped front suspension covers, billet caps and dash surround
Spyderpops 3D SS Grille set
Don't know..!!
haven't lost any but did replace it with the running light/license light combo. Put some black silicone around the edges before installing. Add a dab on the screw and should stay on...
2012 RS sm5
The black silicone sounds good. Thanks for the tip.
Mike
first time I lost one I bitched to BRP and they gave me a new one. second time I wrapped black gloss duct tape around the crack between the frame and the lens housing. then I put a dot of superglue on the lens screw. no trouble now last 4 years. if I ever need to replace the bulb, I can undo the above easy.
Former Navy LT, Retired Chemical Dependency Therapist, Retired Widower, "Do, or do not, there is no try"... Jedi Master Yoda.
Proud member of AA, PGR, and a Navy Shellback!
SpyderLovers Sponsor
