Results 1 to 11 of 11
    Registered Users smporter420's Avatar
    Dec 2011
    Eagle Grove, Iowa
    Question TRIC LED Tric Rings Install/Wiring
    I have read the Installation Guide that came with them and the part where you connect the battery+ (hotwire) to the toggle switch and the connecting blocks, where does the hot wire come from? Do you have to run the + and - wires from the battery or fuse panel?
    May 2013
    Stanton, ca
    Can you scan and post the instructions?
    I can have a look for you.
    Bob
    2011 RT-S SM5 - Black
    Dec 2011
    Eagle Grove, Iowa
    Instructions
    May 2013
    Stanton, ca
    Quote Originally Posted by smporter420 View Post
    His instructions do not say specifically. Kind of a bummer there. So I would pick off to the closest source. Probably the fuse box for you spyder?
    I do not know where the battery is on your model.
    Bob
    Dec 2011
    Eagle Grove, Iowa
    Default TRIC RINGS
    The fuse box has only one open spot for accessories and is only a 3amp fuse. Instructions say to use a 10amp fuse. My battery is the rear end. Can you run +Red -Black strait from the battery terminals ? I have 14ga wire for low voltage applications and an ATM inline fuse holder.
    Default Sure..!!
    as long as you install that 10 amp fuse in line to avoid overloads. Remenber those led are polarity sensative so if they don't work you may have to switch the wires..good luck..
    ​2012 RS sm5
    Dec 2011
    Eagle Grove, Iowa
    Finished wiring tric rings
    Sent from my SCH-R950 using Tapatalk 2
    Registered Users NZSpyderRyder's Avatar
    Mar 2014
    Waiuku, New Zealand
    Default Rings for Australian spec ST Ltd
    Are the headlight and fog light rings the same size ?
    The reason I ask this is because hear in New Zealand our day running lights are where your fog lights are and I want to fit a set of rings around these, the problem I have is that the kits come as either 2 headlamps or 4 headlamps and fog lamps.
    The other question is, can you tap into the existing light wiring so the rings come on at the same time ? and leave out the switch.
    Your help will be greatly appreciated.
    Alan:
    2013 Spyder ST Limited
    TBR
    Black Series Slip-On Exhaust with M-5 Carbon Canister and P1X power tip and black bolt kit
    Fox Podium shocks
    BRP Carbon black sports rack & backrest
    Custom Dynamics LED converted taillights & black tag bolts
    WrapMySpyder carbon dash kit & GT stripes & graphics
    Bestem USA carbon side fairings, belt guards & under tail
    Procoat NZ powder coated wheels
    Hydrographics NZ carbon dipped front suspension covers, billet caps and dash surround
    Spyderpops 3D SS Grille set
    Dec 2011
    Eagle Grove, Iowa
    Yes they are the same size, I'm sure there is a way to wire them to the head lamps. I did it as per instructions said. Wired strait of the battery with an inline fuse.
    Very Active Member ARCTIC's Avatar
    May 2012
    IOWA
    Looks very nice. If that bike didn't get noticed before it will now
    2017 Chevrolet Camaro SS convertible. 2017 GMC Sierra cc diesel. 2017 Arctic cat RR 137 ES
    Apr 2013
    New Mexico
    Hi. I am interested in purchasing a set of LED rings and was wondering where you finally wire them to.
    Thanks
