Radio reception degraded when brake applied
Seems like a power drain that when I apply the brake, the FM reception on my '14 RT-S SE6 turns to c**p. Sounds like it does when you pass under powerlines or an underpass in your car. Happens on all stations. This seems to possibly related to the crystal dynamics HM brake bar I installed. Doesn't seem likely that LEDs would draw that much power but I'm puzzled.
i would unplug it and try it you never know they may have made their plug wrong i have had that happen
Originally Posted by Rattigan_Roger
It’s not a power drain it’s rf(radio frequency) interference generated by the module.
I’m not familiar with it but I bet your wiring or the module is located next to the antenna
It is routed on the same side as the antenna but that's the route the instructions had. I'll try moving it and see. There's not module per se; just plugs into the right tail light wiring harness.
Radio reception..!!
interference would be the problem. I'm sure if you disconnect radio will be fine but the thing is to have both. Extending the connection, to another location may help or some kind of filter. Might also as the light supplier about it..
Tags for this Thread
