doing what we can....
Ever hopeful!!!!
FB got her new 2014 panels this week.. we will be installing them this weekend! the flash to the ecm seemed to help a lot.. but we have not had HOT weather to test it out. Hoping the ventilation with the new panels will help cool the engine bay!!!!
Going to Spyderfest will be the start of a good test! Ever optimistic.. We REALLY want to make this spyder work!!!!!!
. hotglue
Looks like you are putting a considerable effort in making it work. I hope as do we all that this will do the trick...good luck
Sent from my SAMSUNG-SGH-I777 using Tapatalk 2
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
HG, we are all hoping this is works and gets FB happy with her ryde. She deserves a Spyder she can enjoy and ryde with confidence that she won't get stranded...again. Best of luck to you two...see 'ya at SF!
2016 F3-L Special Series? Mods: Lamonster IPS end caps w/ Gripper 3rd pegs, GPS mount, Power Plate, Perf. Muffler; Backoff Brake Light Strobe; CD Front (amber/red) Brightsides & Tip Kit; ISCI Flag Holder w/Long Poles; BRP Signature Light, Aux Lights, Saddlebag Liners, Garmin 590 GPS; TricLED foam Grips, LEDs (Aux/headlights); Pitbull Driving Lights; RDL seat; Ultimate backrest
Previous ryde: 2012 RT-L, 26,636 miles on it when traded; 2014 RT-L, 34,147 miles on it when traded
MOgang Member
New Panels
Hope everything works for FB. Hope to see you both at Spyderfest.
Let's Ryde!
Nobody will be able to say you guys didn't make a 110% effort to make it work.
Rewaco RF-1 GT
Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
0-60mph: 5.8 seconds
5 speed sync manual with reverse, mechanical dry clutch.
Front suspension: Trapezoidal fork with center spring
Rear suspension: Independent with Bilstein gas shock absorbers
Brake System: Grimeca calipers, linked ventilated discs, with booster
10.57 gallons
HG & FB you know my feelings, all ST owners should be sent those or dealer install them, so keep us updated on how it all works out. Hope this summer has less drama than last one for all us '13 owners
2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
Here's hoping the update & new panels turn your Spyder into the machine you were hoping to have!
Have a great time at Spyderfest and a safe trip!
Well three of the panels were ok.. the left front panel was not final sanded and clear coated .. pretty rough... and will not go on the bike like that.... why would they send that part out????? I'm at a loss to figure this out... They have NO understanding of quality control....
So...I would not put it on.... BRP would say that we put the part on and it is used and will not get us the right part.... that is how things work with brp... so we will come to spyderfest 1/2 assed fixed... which Is the brp way.... FB will be coming to Spyderfest ... half done... the right side is on, but the left side is not...pretty much SUCKS!!!! but we are becoming used to it dealing with brp...
on the bright side.. folks will be able to see the difference between the 2013 and 2014 side panels.... all ya have to do is look at each side of FB's bike....
What a shame BRP is........I mean, PLEASE !!!!!! You'd think they would inspect each part before sending it out to the customer.
Bring it to Spyderfest and park next to their trailer so everybody can see their quality contol
2008 GS.....PE # 2888
