Results 1 to 17 of 17
    Apr 2013
    Twinsburg, Ohio
    Default 2014 Semi-Auto clutch over the earlier years?
    Can anyone discuss the 2014 semi auto performance (clutchburn out) as compared to the earlier years? Is there still a great risk ofburning it up if you ride below a certain RPMs?
    I want to trade in my 2012 RT-S Manual and I'm concerned a bit.
    Very Active Member tobor9's Avatar
    May 2011
    Charleston,SC
    The new '14 RT uses a hydraulic clutch, the others have a centrifugal clutch. The new one is not subject to the same problems as the old one as it does not use centrifugal forces to keep it engaged . I don't know if it has any weaknesses but they will be different!
    2015 RT White,Tj's Dash mount,Rivco's Duel Flag Holder,SealsFloorBoards(Pups),Custom Dynamics fender lights(R/W)Bajaron's Swaybar & links,Lamonster's LED headlights,lidlox.Wiredux A-arm driving lights(upper&lower)FOBO TPMS system,Spyerpops lighted bumpskid,Foom handgrips.
    tobor9@me.com
    2010 RTS-SE, Orbital Blue
    Sep 2009
    illinois
    On my '14 RTS, I've found out that I need to let it warm up longer than my '10 RTS. I guess that makes sense, since the '14 needs to build oil pressure for the clutch to work properly, and the '10 only needed RPM's.
    Very Active Member BikerDoc's Avatar
    Clermont, Florida
    After 2500 miles on test bike and 8700 miles on my 2014 rt ltd I conclude shifting is much smoother and overall performance much better than either my 2010 or 2012
    220,000 Mile Spyder Ryder, IBA Premier member #59352, Saddlesore 1000 (11), Bun Burner 1500 (3), Saddlesore 2000 (2), Bun Burner Gold, MILEEATER SILVER
    happy old fart stillriding's Avatar
    Apr 2010
    Elyria, OH
    [QUOTE=Rangeguy405;794636]Can anyone discuss the 2014 semi auto performance (clutchburn out) as compared to the earlier years? Is there still a great risk ofburning it up if you ride below a certain RPMs?
    Apparently there's a problem with slipping clutches on some of the '14s with the SE6 tranny. A service bulletin has been issued and I have an appointment next week to address it. I have NOT noticed any slippage on my RTS.
    Default As I see it..!!
    This is a totally new system in a new engine so there is not much to go on. Gear ratios are different making for a smother shift less change from one gear to the next. There have been some issue with the clutch as to slipping and noise but we shall see in time...
    ​2012 RS sm5
    Bottom line: no need to worry about toasting your clutch plates with the 2014 system.
    Still waiting to get my hands on one. Will give some impressions at 1000 miles or so.
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by s[SIZE=3
    [/SIZE]
    If you have any more info on this bulletin, can you share it with us? I think i've read everything on this forum about the
    14 and don't recall seeing anything about slipping clutches.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Nobody has seen or heard anyting "official" yet...
    Do you have a T.S.B. #?
    Apr 2010
    Elyria, OH
    Sorry guys. I don't have a TSB number or details. It's in the shop now and when it's done next week I'll pass along as much info as I can.
    Apr 2010
    Elyria, OH
    Default UPDATE ON CLUTCH SLIPPING TSB
    Got my '14 RTS back yesterday after two TSBs were checked out. One was the potential oil leak because of an improper manufacturing problem involving a screw's insertion. The other was to check for clutch slippage on the SE6. Mine was inspected and found to be OK. I got all fresh oil, too. (Not filters). The way it was explained to me, and this is going to be in ultra-simple terms, is there are two pistons involved in the operation of the clutch. In some models the brackets that hold these pistons were installed improperly allowing these pistons to "extend out" too far allowing the clutch to slip. The remedy is to correct the placement of those brackets. Mine had been installed correctly. I didn't get the TSB number. It looks like my dealer, JohnnyK's Powersports in Burbank, OH, took a proactive approach by calling me to have this situation checked out. Perhaps many dealers are waiting to see if their customers report a problem. However, my dealer knew nothing about a CB radio problem as reported on Spyderlovers about a week ago and therefore couldn't do anything, yet.
    Do you have a phone number for your dealer handy?
    I'll give them a call, and see if they'll give the T.S.B.# to me...
    Thanks!
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by stillriding View Post
    If yours had the leaky screw it must have been one of the earler ones. Whats the build date on yours? Theres white tags stuck all over the place that show the date. One is under the frunk lid.
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Bryant, Arkansas
    Quote Originally Posted by BikerDoc View Post
    (only 4700 miles)
    Cruzr Joe
    Apr 2010
    Elyria, OH
    Thanks!
    Once JohnnyK's number is 330-302-4155. Once the recorded bull starts on the phone, hit 0 and you'll get a human. The service manager's name is Ron.
    Apr 2010
    Elyria, OH
    Quote Originally Posted by ulflyer View Post
    All of those white tags show Jan. 6, 2014. By the way, do you know what the date on the swing arm represents? Mine says Jan. 20, 2014, but because I first saw my Spyder on January 23rd there's no way it could have been readied for shipping, shipped and fully assembled in only three days!
