Results 1 to 21 of 21
    Active Member Air Force PAO's Avatar
    Jul 2011
    Kyle, TX
    Default Semi-automatic transmission operation questions
    Howdy. Friday, I am picking up a 2010 RT Ltd with the semi-automatic transmission.
    Other than twist the throttle, how do I move the bike through the gears? What is the small lever on the left handlebar grip?
    Thanks, just want to know how things work before I get to the bike.
    Test message.
    2016 Spyder RT
    Shift gears between 5000-5500 rpms. The lever on the left with the + on it is pushed with the thumb to shift up. A pull with the index finger on the backside will downshift your Spyder. The Spyder will also downshift by itself. For more detailed information--recommend checking out the owners manual.
    Aug 2013
    To start I would watch the RPMs, you want to keep it at least 4000rpm, your bike likes RPMs.
    When you start going and hit 4-5000 rpm hit the + and it up shifts .
    Again in when it hits 4-5000 rpm hit the + to up shift.
    For now it will downshift on its own....saying you don't know how to downshift....
    that is a starting lesson....you will get the hang of it and it will grow on you from there...
    hope I got it right.
    Aug 2013
    I gave minimums lol.
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    Red face SE5 shifting.....imo
    Upshift @ 5K+
    Downshift manually @ 4K (no lower than 3700 or so. That will keep the centrifugal clutch locked).
    Have fun
    Aug 2013
    As you notice, everyone is confirming what the GREAT SNOOPY has already said.
    A 2010 Limited?
    (They didn't make one that year...)
    The advice on shifting is pretty darn good...
    Keeping your engine at 3,500 rpm or better, will ensure that the clutch has fully locked-up, and your clutch plates are happy. (As in; NOT getting burned up!)
    When I had my 2010; I would hit the upshift paddle at about 5,000 rpm; that would drop me back to about 4,000 in the next gear.
    Use your index finger to downshift...
    If you wanted to have more power for a pasing maneuver
    Just to help with slowing down before a sharp curve or turn
    Unlike the typical manual transmission; you don't need to back-off the throttle for any of your shifting. The engine management system handles that chore for you!
    Apr 2012
    Red face
    Quote Originally Posted by SNOOPY View Post
    As you notice,notveryone is confirming what the GREAT SNOOPY has already said.
    Perhaps something was missed. Doesn't your post say upshift between 4 & 5K?
    Just asking, Snoop.
    Active Member can-am sam's Avatar
    Jun 2010
    Ferndale, Washington
    When shifting to a higher gear, do not let off of the throttle. If you do it confuses the computer. Remember to upshift at 4500 or higher rpms. The higher the revs the faster the shift. To downshift let off the throttle and use your index finger to shift to a lower gear.
    Default There you go...!!
    Once you start her up you will press tha + tab on the left hand bar. This will be first gear. Run up over 3,500 rpm's ( only fully engages at this range) then press the + again you are now in second gear....then third forth and fifth. As stated the engine/clutch sysytem will down shift automatically and you need not do it manually. But if you get comfortable and want to do it you use the index finger on the tab on the opposite side of the bar and come back down. There is a video and clear instuctions with the roadster...relax and enjoy...congrats and some pics are required...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Aug 2013
    Quote Originally Posted by Jerbear View Post
    Just asking, Snoop.
    Yes, I'm correct. You all are wrong. lol
    Don't you just live trolls lol
    A 2010 Limited?
    I was thinking he meant RTS--that was the top of the line in 2010.
    Aug 2013
    He did say LTD, but maybe he's not sure.
    Either way; it's a great bike, and he'll have an even greater time with it!
    Apr 2012
    Florida
    Lots of great advice here. Just keep poking around. Tom
    2020 Petrol Blue Metallic RTL
    Jul 2011
    Kyle, TX
    Default Semi-automatic tranny
    Thank you all for the advice. I did learn a lot. I did not know about pressing the +tab to upshift.
    Bob, you are right, again, it is a 2011.
    Let's ryde.
    Test message.
    2016 Spyder RT
    Very Active Member finless's Avatar
    May 2013
    Stanton, ca
    Did you get the manual and CD with the bike? The CD has videos and is pretty nice and explains a lot on how to ride, shift, practice, etc. I highly reccomend it. Shifting is not the only thing you should know before you get on it!
    Bob
    2011 RT-S SM5 - Black
    Quote Originally Posted by Air Force PAO View Post
    Let's ryde.
    I'm just living proof that, "Even a blind Hog; will find an acorn once in a while".
    Invalid Emails
    Mar 2011
    Hudsonville, MI
    Practice in a parking lot...hopefully you don't have to drive far to get home. Great bike/great choice...
    Invalid Emails
    Jan 2012
    Huntsville, Al.
    Bob, with sayings like that I think your just a good ole southern boy at heart.
    A "New Yawka", only due to an accident in Geography!
    My Grandma Denman was from Scottsville, Va.
    (Maiden name: Phillips)
