BajaRon Sway Bar Links
I just received by BajaRon Sway Bar from SpyderPops, however I hear some if you referring to new links. Can you use the new Sway Bar with the original links?
No problem using the factory links.
The big difference is the factory links have a plastic casing and Ron's are Metal.
I put them on my Spyder and well worth the price.
Here's a link to the original thread.
http://www.spyderlovers.com/forums/s...im+Joint+Links
Not to worry..!!
You can run with oem hiem joints. If you have not changed the bar yet it is worth getting the joints as well. Ron ships fast but changing them after is quite easy. There weresome faulty ones and I just feel better with the metal ones...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Happy and safe rydin'
2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
Thanks, I got with Ron and ordered his Heim Joint Link set since I have not yet begun the install.
You won't be disappointed!
I've still got the OEM bar under mine, (haven't decided if I need Ron's Bar just yet...), but his links are holding each end of it in contact with the A-arms!
