Originally Posted by Rattigan_Roger
They are held in by tabs that fit into slots on the dash.
Carefully wedge a screwdriver under the grill and separate the grill cover from the dash.
If you can get one corner off they all will come out.
But I use a putty knife as it was wider and thinner.
How the front speaker grilles pop out of these RTs?
I've got an idea; and it MIGHT work! (might...)
I've always heard, that the factory XM radio reception wasn't great with a passenger on board...
My "El-Cheapo" very aftermarket setup suffers also.
I wonder if the XM antenna, (That little pod thingie), could be slid up behind one of the front speaker grilles?
2011 RT LTD /MODS: Seal Floorboards, Elkas, SpyderPops Bump Skid and Block off plate, HMT Brake light, BajaRon's sway bar, Heim Links, Diamond R's passenger armrest, Utopia driver backrest
Where would you suggest that I start the prying.
I removed mine starting with the outside end. Also, when I ran my cheap xm radio I had mounted the antenna to the inside of the trunk lid, it worked perfectly.
2014 RT S SE-6 Cognac, 2014 Indian Chieftain. Retired Navy Chief
Now 2014 RT Limited Cognac
Was 2008 GS SM5
Don Garbarino
Cup Holder
GPS locking holder
Mud flap
Modified KNOTT grill
Phone holder and charger
Trailer hitch
Dual air horn
Auxiliary fuse box with relays
Heated clothing controller
volt/oil pressure gauge
Sequential signals in mirror
Tri Axis Handle bars
Baja Ron anti sway bar/heim links
shorty antenna
And many more
Follow this link to a video to pop off grill..
Watch this video, I believe he shows you an easy way to get it off right in the vid
http://www.spyderlovers.com/forums/m...etails&mid=475
Thanks, Al!
I've got my antenna tucked up in there also. When the Missus is on her perch, she must be blocking reception...
Bob, at first I had the same problem, seems with 2 up the reception was blocked a bit. It took a couple of times but I finally found the hot spot for it in the lid even with ryding 2 up
So where is it??
Or would this require killing me; after the secret is divulged?
hmm in the name of the dead terrorist "Silence!!, I Keel you!!!"
It was off to the right of center if you look facing the trunk, in the center it would break up, to the left it would break up no matter what direction we were going when I shifted it to the right of center "Bam" worked great. It is all going to depend on that little thing up there in space.
Originally Posted by ZDarkman
I don't think Bob watches my videos or he would have caught that simple way to do it.
Bob
2011 RT-S SM5 - Black
Bob
That would involve Too Much effort and Cut down on his posting time? "Don,t Chaa Nooo?"
Sea Doo GTI-SE 90 Jet Ski!!
Thanks Al!
I actually did watch most of the video... I figured that I must have missed it when you started discussing stereo versus mono inputs, and getting sound out of both speaker sides... SORRY!
