passenger floorboard adjustment
Ok I need help. What needs to be done to adjust the passenger floorboard son a 2012 RTS. I haven't had a chance to really check this but I figured I'd ask the pros on this board first before I get stupid.
Loosen the bolt under the floor board and slide the floor board up or down. You don't have to take it all the way out.
2014 RT Limited Cognac ----- Wraps, skid plate, lights, Elkas
2002 harley ultra classic
2008 hayabusa
Mine had 2 nuts on each board, a jam nut locks it tight that way.
2012 RT-S Pure Magnesium Metallic, Web Boards in Black Line-X Closed pattern, Bajaron sway bar and links, Spyderpop's Bump Skid, GloRyder remote controlled lights, show chrome rear rack, cargo nets in the all three rear bags, more to come........
I use an allen wrench to loosen a single cap screw on my 2011, then slide the foot board up or down and retighten.
2016 RT-S Special Series
(You might need to flip the board up; for easier access to the hardware...)
Motorbike Professor
I believe the procedure is in your owners manual.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Allen wrench is a no no
The floorboard bolt is TORX and cost it costs almost $9 USD.but simple to repair or replace you got together dirty but that's half the fun
