Upper belt guard
I saw this on an earlier thread, but no answer. How do you reach the nuts behind the upper belt guard in order to take out the screws and then install "the missing belt guard" from spyderpops? I can feel the one closest to the front of the Spyder, but not the one at the rear. Any help would be really appreciated.
Motorbike Professor
I did it by feel, using a 10 mm combination or box wrench...or maybe a ratcheting box wrench. I don't remember for sure. It helps to hold your mouth right and give some verbal encouragement (i.e. cuss words).
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Have to agree..!!
been a while but I know it was a bit of a chore. What I do remember is I replaced them with clip on nut like on the body panels so I don't have to do it again....
2012 RS sm5
I use the round end of a 10mm wrench. Go in from the front and use your fingers to guide it on the bolt.
As stated above, to find the screw of the upper belt guard on the RT you will need to feel on the inside. Use a 10 mm box wrench. You will only need to do this once as Spyderpop's belt guard kit has the necessary parts to make the re-installation of the upper belt guard easier.
May all your encounters with the law begin with the words: "nice trike!".[/B]
2015 Can-Am Spyder F3-S SM-6 Can-am Red/Black SM-6 with 2010 Black RT-622 trailer (hitch in the works).
Previously owned:
2010 Can-Am Spyder RT SM-5
2011 Can-Am Spyder RS-S SM-5
2013 Can-Am Spyder RT-S SM-5
Thanks to all for the advice, got it done this morning. Pain in the neck getting the very front bolt back on, but boy I was sure glad that Spyderpops included the blind nuts to replace the 10mm stock nuts.
