Custom Dynamics HMT Center Light with Turn Signals
Just installed HMT center light on my 2014. Everything works correctly except when the turn signals are activated they blink normal then rapid. Any idea what I should look for? I've checked connections, etc. ???? I'm at a Loss.
Ron
Yes you have to calibrate you're flasher
1- ignition on
2- 4 way flasher push and hold the button until you see light flash in dash
3- job done
Check for the thread on resetting flashers. It has something to do with holding your tongue right while holding down a button. It should recalibrate the brain.
[QUOTE=R30SHIRE;788776]Just installed HMT center light on my 2014. Everything works correctly except when the turn signals are activated they blink normal then rapid. Any idea what I should look for? I've checked connections, etc. ???? I'm at a Loss.
Check out "flasher reset" under spyder shop talk in the current forum. Worked for me!
GUZZI :
2020 RTL blue
I'll try that. Thanks
1- ignition on
2- 4 way flasher push and hold the button for 30 seconds or until you see light flash in dash
3- Flash is reset.
Cruzr Joe
FYI the flasher reset does not work on 2013 and older bikes.
Amazing. It worked. Newly installed Custom Dynamics HMT with integrated turn signals now work properly.
Pretty simple fix huh? Glad all is well, and the HMT with turn signals works great!,
GUZZI :
2020 RTL blue
Not one doubt. This website is always so helpful.
Ok, so now the question is does the "Custom Dynamics HMT Center Light with Turn Signals" work/flash properly on 2013 RTL??
Living Life, Loving Life
2017 F3T - Monolith Black Satin
2015 RTS - Intense Red Pearl
2013 RTL - Lava Bronze - Retired
Don't know for sure as I intentionally bought the one without the turn signals but I suspect it will not work plug n play just as LED bulbs for the turn signals will not work.
The CD strobe box does not work plug n play on the 13s either.
Yes, it's does.
