Sounds like you may have got it if they still don't work I can pull off the panels and take pics of the connectors and location but there pretty much plug and play once the connector is assembled
I did the BRP HIDS on my 13 that took a little bit of figuring but still wasn't hard
Originally Posted by WasWinger
Yep, accidentally connecting power to ground will do it every time! That's why every circuit needs to be protected by a fuse!
I think you've got it made now!
YEESSS!!!!! They work!!!!
Thanks for all of your help!!
Yes,.. Finally!! At least now I know more about the bike and taking it apart. I will most likely upgrade to HIDs soon. For now, are there any upgraded replacement bulbs that will give you better output than stock ones? I also installed the tricled light rings and difference of the two is very noticeable.
Fog lights won't work
There are better bulbs you can get , just watch going higher wattage could damage the wiring due to the higher amp draw.
If you wanna do HIDS depending on what you decide I would just go for those . Sylvania silver star bulbs are almost $50 a set the aftermarket HID kits don't cost much more then that. I installed the BRP hid kit and thats the way to go if you wanna swing the extra cost. I got mine from a dealer that was on clearance since BRP say they only fit 2012
I can tell you that they do work on 2013 by simply cutting and soldiering the 2 small jumper headlight harness. If you can soldier the wiring is a piece of cake.
Install is little involved since you replacing both the headlight assemblies and not just adding bulbs and ballasts.
Bill
2013 RSS Neutron Green
BRP HID's and Fogs
Custom Belt Tension
2014 side panels
HMF Exhaust
K&N air filter
Bajaron sway bar and links
Thanks for the info.
Looks good
Like the hallo LEDs
Bill
BRP HID's and Fogs
Custom Belt Tension
2014 side panels
HMF Exhaust
K&N air filter
