Results 1 to 16 of 16
    Active Member SpyderRx's Avatar
    Brookhaven, MS
    Default Check transmission
    Got back from about an 80 mile ride today and parked my bike in the driveway. Got on and started it back up to pull in the garage and got a check transmission and it wouldn't shift into gear. Turned it off and let it sit for a minute and started it back up and no problem. Went right into gear and no light on. Pulled in garage and checked for codes and showed no active codes. So was it just a glitch or do you think it's a forewarning of something going wrong?
    2014 Silver Platinum ST Limited: Mods so far: fog lights, passenger backrest, ultimate seat w/driver backrest, rivco drink holder bracket with ram x-grip cell phone holder
    Default Don't know..!!
    Could be the gear position sensor or it was between gears. Not to familiar with the se trans but could be a glitch. You could run by the dealer and have them check with buds for code history. Make sure your oil level is good...
    ​2012 RS sm5
    Feb 2013
    UK
    Cool
    You can get the 'Check Transmission' light if you're in neutral and try to shift into gear
    with high engine revs.
    1. You can't get into 1st. until the engine is almost at tick-over.
    2. If you try to shift, there will be no gear engaged, but when you move off
    the light will come on for a short time.
    I've managed this on a couple of occasions!
    Brookhaven, MS
    Quote Originally Posted by OJ UK View Post
    Hopefully that is all it was. Thanks for the info!
    Just for fun...
    Check your oil levels.
    That's been known to make a transmission act a bit "wonky", at times.
    Brookhaven, MS
    Got a check transmission message again today. Had a code P099 listed. Can't find any info on this code.
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by SpyderRx View Post
    You're missing a digit.
    2018 F3 LIMITED
    Jun 2011
    erlanger, ky
    I have been having a transmission code on mine also. I was not able to pull up a code. The oil is OK checked fuses,relays and the battery connections. When the check trans code came up it would not let me shift up or down until the code left the screen. The shop pulled up two codes on it. One for the paddle shifter and a speed sensor. I should get it back next week .
    Brookhaven, MS
    Quote Originally Posted by SporterSpider View Post
    Do you know if they are replacing anything or what codes it showed?
    Brookhaven, MS
    Pretty sure my code was P0990
    Registered Users autosapper's Avatar
    May 2014
    belarus
    Good afternoon. I have a similar problem.
    spyder rs 2010
    error:
    C0040
    P2545
    P099-
    please help. I live in Belarus. no nearest dealer BRP
    May 2014
    belarus
    thank you.
    I can not find error P099-
    What does this mean?
    May 2014
    belarus
    three post above my video
    P099- now on the screen
    Default SAME / SIMILAR ISSUE
    While at Spyderfest 2014, a Tech at the BRP Truck tore my 2011 RSS down and cleaned everything and after checking all possibilities He narrowed it down to the Shifter / Paddle switch ( ( BLIPPER switch )( SE ) as the likely culprit. I had been having intermittent codes and only had the trans actually get stuck in gear a few times ( but it did correct itself after revving it ) . It's now at the dealer and I await what they are going to do about it .........Mike
    Brookhaven, MS
    When I ha mine in the shop I had to apparent problems. The code was for the blipper switch however the switch tested fine. The tech notied that sometime my throttle did not quite return all the way to the top. He said if it is left open a little it will not start and throw that code. My other problem that could have been the possible culprit was a loose relay or fuse. Non problems since then for me.
