WHAT SIZE TORX?
What size torx is needed to remove the oil and engine drain plugs when doing an oil change?
2020 F3 Ltd
Spyderpops Bumpskid
Motorbike Professor
Other than the new ACE1300 in the 2014 RT, and some early 2008 GS plugs, the 990 & 991 series engine and tank plugs have been hex, not torx. Check yours carefully to be sure. Use of the wrong tool will damage the plugs.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Size
Do you know the hex size?
2020 F3 Ltd
Spyderpops Bumpskid
6mm Hex
Marilyn 2023 RTL Red
John 2023 RTL Black
previous:
2015 RTS SE6 Red
2015 F3S SE6 Silver
2011 RT SM5 Silver
2013 STS SM5 Silver
"common sense will prevail....but we see no sign of that"
